Best cushioned motion control trainers?
Having a stress fracture to my L5 I have been advised to get the best cushioned motion control trainers I can afford.
I change my current Saucony stabil MC5’s every 3 mths or 250 miles(the forefoot seems to compress any higher mileage than this) but I have had some problems with referred sciatic problems.
My PT has recommended Asic’s but has anyone else with back problems got any recommendations?
Hello Gary and All,
Check out Z-Coil. http://www.zcoil.com/
Lowest impact I can find.
I have used them for over a year with good results for training with torn miniscus.
The heel can be rotated through 90 degree positions to correct for various pronation conditions too.
They are easy to stumble in however as you ride a bit higher than usual, so you need to be conscious of your footing.
Also they pitch your body forward a bit and you might notice a bit of back tiredness at first, so like any new gear, use them in reduced increments to start.
Cheers,
Neal
“stress fracture to my L5”
I assume you mean 5th lumbar vertebra or do you mean left 5th metatarsal
Male/female? How old are you. High arch, rigid foot?
The stress fracture is to the lumber spine, bilateral fracture to the pars interarticularis(?).
I have high arches 6 feet tall and around 75KG’s. Started using motion control shoes due to ITB problems and had none since.
Tough is you need some motion control for ITBS, yet cusion with a rigid foot and history of a vertebral compression/stress fracture. Many people like/do well in ASICS Gel Kayano, but I would recommend a more neutral/cushioned shoe like the Gel Nimbus. You would always go an orthotic (custom might be needed with your foot) and stay with a lighter, neutral cushioned shoe (that way you get the best of both). I would also speculate that you really don’t need a motion control shoe.
mizuno wave nirvana II’s.
I ran in Kayanos for years but didn’t like the latest version (the 12s).
Had knee surgery in august and been using the Mizunos since then…very cushy ride and comfortable. A bit heavy though…
coming from a guy who sells shoes…
I’d say if you need motion control and max cushioning either the Brooks Beast which has a bit more motion control, or the Nike (yes Nike) Equalon is an awesome motion control shoe with just crazy amounts of cush.
Good semi motion/stability shoes are the Kayano, Saucony Hurricane, Brooks Trance, high end NB stability shoes
The Nirvana is an awesome shoe and as my training buddy just stated “these shoes are amazing!!! they totally changed the way I run, I’ve never loved running so much before…” Seriously, some people just go crazy over those Nirvanas… Not super duper motion control though and honestly I think they are a bit firm but worth a try.
