BB30 bike/cranks question
Is there any reason to not put a cannondale BB30 crank/bearings on my new parlee? I’m planning to pick up the hollowgram sl and figured I would ask first in case I’m missing something…this is my first BB30 bike.
good choice.
seems to be pretty solid set up and only 580 grams including bearings…seems like a logical choice if you can live with “cannondale” on your crank arms.
Really only reason not to is if you plan on going smaller than 170mm.
If so, S-Works or Rotor would be other options.
Stiff, light, and solid design which is why I use a Hollowgram SL SRM on my CX bike.
Is there any reason to not put a cannondale BB30 crank/bearings on my new parlee?I was under the impression Parlee had opted to build with the Press-Fit 30 bottom bracket standard or does the customer decide?
Get the correct crank length first (zenncycles.com) then worry about the brand and model only if they fit your body first.
Also, SRAM Red and Force both are available in BB30 and with 165 and 167.5mm crankarms.
Asad
i have a BB30 specialized 167.5 only 200 miles on them $225 + shipping.
No reason why this won’t work. Vision is another brand to consider.
Super nice set up
