I am currently in my base phase of training for IMAZ. I’m really enjoying the zone 1-2 work in these phases, feels nice to slow down a bit. I would like to work in a tempo run weekly but dont know if this will have any negative effects on my process of building my aerobic base at this point? I’ve read that in base work you don’t really want to go into anything above zone 2 and naturally tempo work will put me well into zone 3.
Another question I have is I was going to start doing a weekly stride workout prior to one of my runs but its sorta the same question, will these short bursts of higher heart rate have any negative impact on me in my base period? Especially prior to a run that I’m guna do in zones 1-2? This leads to another issue.
I am currently dealing with some sore hamstrings that seem to be limiting my ability to do strides at this point even if its ok to do during my base period, any advice on how to loosen them up? just stretching? I think I might have injured them doing a long hill run a couple months ago and its never felt the same since. I’m not sure if stretching my hamstrings is just aggravating an existing injury. The soreness is near the upper part of the hamstring towards the glut, I suppose it strained it while I was running uphill. Any advice on how to get rid of the nagging pain? It doens’t bother me to run in zone 1-2 for up to 2 hrs but i know some speed work would bother it, I just havent worried too much about it since i’m running easy currently.
Do the striders near the end of your runs. Typically, you’d want to do them on the days when you’re going shorter. That fact that you’ll be warmed up will help your hamstrings. Due to the hammies be sure to accelerate gradually. You may also wanna try stretching them about 10 minutes into your run after you’ve warmed up and then again, more thoroughly, afterwards.
Short (< 20 second) bursts of faster running won’t really impact your base building (i.e. fatigue you and require recovery). Just make sure you recover fully between striders. A good way to do this is on a track where you stide the straights and slow jog the curves. In any case, I found it’s a lot easier on my body to do my striders on a softer surface. The football field at the high school next door to my house is made from one of the new synthetic turfs. It’s a dream for striders.
For the stride workouts, warm up for 10 minutes, then do one every ~3 minutes (~100 yds). You should recover completely between each one. Leave yourself 10 minutes of easy jogging at the end. It should have a minimal recovery cost if done right.
trukweaz, I had been following barryp’s posts lately but I never saw anyhting specifically addressing tempos running in base periods thats partly why im asking. It did say benifits can be realized from doing them year round and perhaps that answers my question, but I just wanted to be certain that during base period the tempo run wouldnt have any negative impacts.
I guess all throw in another question while im at it, I’m currently running 4 times a week, that’s 3 standalone runs, and 1 short transition run after my long ride. Should I really be shooting for at least 4 stand alone runs with that transition run on top of that?
I believe BP has stated that 20 min of LT/Tempo work a week year round is something he likes to do regardless of training period–and I agree. In your early base you need to throw in some above zone 2 efforts now and then. I like to go on fartlek type runs to see where my fitness is and to condition my legs for the real work of LT/Tempo running that comes later.
Thanks!
just giving myself a bump to get some input on this question.
Thanks!
In my opinion, increasing your frequency with running is probably the second most important thing you can do to improve your run fitness with the first being consistency. If you are able to fit four runs plus a T-run I would definitely do that. After a month of that, I would probably look to add another run in there as well.
Check out desert dude’s thread on the full assed challenge - some great advice there about improving run fitness.
Doing some speedwork or whatever will have NO negative impact on the aerobic adaptations that you are trying to achieve in your base period. That old theory is a bunch of bunk put out by Dr. Maffetone. He does not have enough of a solid background in muscle physiology to understand the issue. All you are doing when you are running faster is recruiting more motor units (faster twitch motor units). This has no impact on what the slow twitch motor units are doing (except they get to use some lactic acid for fuel). The slow twitch units don’t really know the difference. There may be good reasons not to include temp running during your base building but the idea that it will ruin your base period adaptations is bunk.
It all depends on what you are going to leave as a limiting factor for your training AND what your level of experience is.
In other words, if you have a set amount of time that you are willing to train that is less than what you are actually capable of training, then yes, you probably want to put in 20 minutes of tempo running a week. However, if you ARE willing to push your limits of training to your potential, then you may want to follow the advice of Coach Gordo…ie most people need more slow running and tempo running will only risk injury.
To give a concrete example, lets say if training time is no object and you could put in 30 hours of training a week (or whatever that numebr is) and within those 30 hours you could push yourself to run 40 to 50 miles a week, you may be better off doing a second long run (like 15 to 18 miles) than a tempo run. However, lets say you only have time to train 18 hours a week which includes 30 to 40 miles a week of running, then a second long run just won’t fit AND 30 to 40 miles a week of slow running just won’t challenge you. In this case, yes, a tempo run would be good.
Personaly, I think a tempo run being done most of the year is good for 90-95% of the cases out there, however, the Ironman for you may or may not be in that other 5-10%.
