I can’t ride my TT/Tri bike more than 1x or 2x per week because of steep hills and traffic. Or rather, to be more precise, I won’t. Since I need lots more time riding aero, I’m thinking that I should at least get my road bike to the Slam position. I saw J Cobb’s article mentions that no production bars work very well, but I think that was a few years ago. What bars are you Slammers happy with?
I bought a pair of VT shorties from BSM. They’re nice bars but they’re about an inch too short to be really comfortable. IMHO they should make them slightly longer for age groupers but put a line on there to hack off to ITU legal length.
I find that they are vastly superior to any other bars I’ve tried because I end up with quite a lot of leverage from having the pads so far forward on the arms that the straightish extensions are the only ones that don’t get tiring for the hands and wrists.
I would second vision tech but you don’t have to go with the shorties. I use the 290mm length Vision tech alloy clipons for my tri setup and also have a 250mm setup which I hold a bit back from the end (possible should of got the 230mm) for my road bike setup. There fantastic aerobars super comfy.
Most of the shorty bars use really small forearm pads which in my opinion just don’t cut it, the standard vision tech pads (not there shorty pads which I have never used) are absolutely awesome.
The problem with not using shorties on a road bike is that you might be too stretched out, especially in a true slam position as described by Cobb where you move your saddle back and down.
I used small size Syntace C2’s on a normal road position with my TCR and found them quite comfortable.
Oval ‘slam’ bars - highly recommended. I used them on my road bike all last year, found them very comfortable.
Cheers
Barry
I just took a look at them – they look really short. Approx how long are yours (and what size top tube do you ride)?
bump
I just put a pair of the new Oval Concepts A910s on my road bike, and I like them better than the Profile Jammer GTs and the Vision Tech minis which I also tried. You may want to consider upgrading the armrest pads to the thicker size but the stock pad is fine to me.
MSRP is about $200 but I got mine for about $125 or so at aebike.com.
Can you link that article you are referring to.
Spinachi, cut-down Deda Clip-Ones would come to mind.
I picked up on Ebay the Oval Concepts A700 ‘Slam’ bars, which Cobb designed for the slam position.
However, I cannot recommend them because they fit poorly my (typical) ‘oversided’ handlebars.
Ken
From the pictures, I like the fact that the arm pads are behind the bars, but it also looks like the stack height is really high. Would you agree?
What other bars would fit the bill with a low stack height?
You could get a pair of HED aerobars and just trim them down.
I have a pair of the new VisionTech mini clip on TT bars that didn’t end up working out for me (my front end is too low). I’ll make you a deal if you’re interested ($50 plus shipping).
Check 'em here: http://www.excelsports.com/new.asp?page=8&description=Mini+Clip-On+Bar+Alloy&vendorCode=VISION&major=1&minor=15
I just ordered a pair of Oval Slams online last night. I looked at the installation instructions on their website and it said that the bar comes with optional lower stacks along with shorter screws. I can’t wait to get them and try them out. I love the fact that the pads are adjustable behind the bar. The oval web-site did recommend a 10-20 mm shorter stem, but I’ll try them with my regular 120mm stem first.
Can you report back and/or post pics of how it goes with the low stack height installation? Much appreciated. Also, where did you order from and how much?
Sure thing about the pics/report. I purchased them from competitivecyclist.com for $100
Here is the oval site… click on assembly instruction and it will give you a parts list
