How can I get my tape jobs to look like this? I get good results cutting the tap at an angle (taper) and starting at the lever end, just not this good. Anyone have any tips/examples? Step by step photos would not only help me out a lot, but also make whoever posts them a faster triathlete (kharmically).
The only tip I can give is to stretch the tape tight. If you don’t, you won’t get that smooth finish. Also, I generally use electrical tape instead of the supplied tape strips because it stretches and doesn’t crinkle as much.
Bar wrapping is definitely a skill but one that anyone can have it just takes practice. I hate wrapping bars just because of the time and precision it takes but here are a few tips.
1.) Probably my best tip here!!! If you have some extra bar tape cut off a little 2-3" section of it. Then slowly start to pull it apart keep pulling on it till it breaks! Why did I just have you do that? B/c the key to bar wrapping that stays is correct tension on the bar wrap. Once you know where the breaking point is you will realize the stuff can take quite a pull and still stay in shape. Now you can really crank on it and get it nice and tight and clean.
2.) Use electrical tape to secure all cables tightly before you wrap the bar. Nothing should be able to move while you are trying to tape your bar.
3.) practice. Thats right practice. If you don’t like the way one side turned out undo it and try again. The more you wrap the quicker you will get and the less times you will have to try again.
I’ve always wrapped my road bikes by starting with a double wrap near the stem and then working my way down to the bar ends. I then jam the excess tape into the bar end and secure it with the plug. I’ve never know any other way. (I always wondered what the little pieces of colored tape that came with the bar tape were for…)
After probably 20 years of taping bars, I’ve finally noticed people are doing it opposite to me. Is this a huge faux pas or is there a good reason for doing it the other (correct?) way and taping near the stem. What’s the deal? Should I conform? Why?
Brad
The way a tape rolls, clock or anti-clock wise, is dependant upon how you ride (roadbike). If you’re a climber, hold onto the cross bar, then you wind it anti-clockwise (looking from the side), this is so when you hold onto the bar, tightly on steep climbs, your pulling with the wrap direction. If you are a sprinter and race in the drops, the the winding goes the other way (I believe).
Hope this makes sense - when you start the wrap near the stem, the overlapping tape will be towards the stem. While riding, if you slide your hands outward (which I sometimes do), the tape edges will catch and roll over. For this reason, I start taping at the bar end and wrap toward the stem. I do the same with aero bars, starting away from the stem or basebar and wraping toward the bike. Now the overlap is away from the stem or basebar and if my hands slide, they slide over the tape and it doesn’t roll (just like the picture above).
I wrap my road bars so that no matter where I’m holding the bar, I’m tightening the tape. In the drops (looking away from the bike, like when riding), I wrap the left side counter-clockwise, keeping this counter-clockwise direction as long as possible up the hoods. When I pass the hoods, I am now wrapping towards myself (if I was looking down the left side of the bar, it would be clockwise). The right drop gets wrapped clockwise, and the tops towards me as well (clockwise if you’re looking down the right side). It’s kind of hard to describe, but it ends up to a point where no matter where I’m holding the bar, I’m pulling the tape tighter.
Also, starting at the stem is sloppy because when your hands slide toward the tops from the hoods, you’re going “against the grain”.
I’ve been practicing wrapping my aerobars and I think the key is cutting a perfect taper, then getting the overlap on the first wrap to match up with the rest of the overlaps. If I can get the technique down a little more, I’ll definitely post step-by-step photos (when I re-wrap my clip-ons).
The best bar taping instructions I’ve found. http://www.spectrum-cycles.com/63.htm
See about halfway down under ‘bar tape tricks’. The superglue thing really works. Especially on regular road bike bars, it looks so clean around the hoods. You have to look at it for a minute, and finally think, wait a sec, how’s it do that?
I agree. On the left side of the bar starting at the bar plug end, I wrap counter clockwise so one’s grip and pressure on the bar after wrapping effectively acts to wrap the tape tighter rather than act to unwrap the bar tape.
On the right side of the bar starting at the bar plug end I wrap clockwise for the same reason.
The photo posted appears to have the tape wrapped clockwise on the left “s” bar. Over time, this cyclist’s grip will tend to loose the bar tape. Maybe he’ll wrap it the other way next time.
