Bar Q for Anyone
Dan (and other helpful gearheads),
I have my bike all nicely set up. Final problem to solve: my armrests are 2cm farther away from the saddle than I desire. No, I’m not going to buy a shorter frame. I can get the bars where I want them with a Look Ergostem, but it’s heavy and ugly and blocks the insert of my Profile bottle. The ITM stem gets low enough, but places the base bar clamp 2cm farther than I wish it to be.
My solutions, as I see them, are:
(1) Get shorter C2s so that my hands are in the right spot. Downside is that that the pads move up my forearms and annoy me. I like my elbows right over the pads.
(2) Find clip-ons that have the pads positioned farther aft of the basebars than the C2s.
Q for you: Is there a brand of bar that has the pads positioned farther rearward than the C2s (or that are adjustable rearward)?
Thanks all!
Take a look at the Profile bars - carbon stryke or aerolite - you may not gain 2cm, but you will get close.
Yes, I think the Carbon Stryke will allow the pads to come back closer to me.
Follow-on Q: Does anyone know whether the armpads on the Carbon Stryke are higher or lower than the C2s? (relative to the base bar)
Hmm, I gotta think about this…
Hey, you’ve gotta have a ruler lying around somewhere… :wink:
Two solutions I have:
1: A 2 cm shorter stem.
2: An ITM adjustable stem.
Syntace puts the armrests pretty far back.
That’s what I’ve got, pointed as far down as it will go.
Under the heading “Do not try this at home,” I’ve figured out a way to get it to point down another 20 degrees or so, making it both a little lower and a little closer to the headtube. A small file and some care, and that thing is more adjustable than you might think.
