Bad pedal stroke. how do i correct?
The person who fitted me on my new bike said I have a very inefficient pedal stroke…what exactly does this mean and how do I correct it?
Best thing I ever did for the pedal stroke was 1 leg drills. Trust me…if you have a bad stroke this will make you improve it.
I was only able to do about 10 rotations per side when I first started. 10 left, 10 right…10 times. Then I moved to distance rather then count. Started at .1 miles…5 times each side. Then up to .25 miles 5 times each side after a few weeks. After a few months I was up to 1 mile each side for 6 miles total. Also got to the point where I was able to do the drills in the aerobars.
It helps alot!!!
It means that your fitter is big on criticizing and not so big on actually helping. to correct, go to someone actually willing to show you how to fix the flaws that they point out (which may, or may not, be there).
-charles
One-legged drills and spinning at a high-cadence help you with learning a correct pedal stroke. Even though later on you can focus on power and maybe low-cadence will work for you, going through a period where you focus on high-cadence helps with learning the pattern.
It’s interesting you say that. I took that advice, without a coach or other supervision, and for a long time worked on my pedal stroke with ILT, high cadence, and rollers. What I learned was how to spin fast and smooth. I never learned how to ride fast! The last person to look at my pedal stroke described my pedaling as only using the interior muscle of the thigh (just above the knee. I have no idea what you call it). We then went through the pedal stroke and things to work on to engage more muscle groups. Wow, free power. Now I just have to ride enough to help those newly recruited muscles develop some endurance!
I never said that you could get faster by doing that.
It helps alot!!!
Very impressive. Way above average as to what most people are willing to do. (most, who will do 30 seconds a side for a few minutes.) If you had only done those 6 miles on PowerCranks it would have been like doing 6 miles ol ILT on each leg instead of 3. And if you had done a 25 or 40 or 100 mile ride it would have been 25, or 40, or 100 miles of ILT.
Frank
You forgot to add that it would be equally useless, with the difference that the poster would be $800 poorer and you $800 richer…
I didn’t mean to imply that you did. Just that pedaling pretty circles wasn’t the entire answer to getting fast.
The case that pedaling circles is not even part of the answer to getting fast is pretty easy to make. And true too :smiley:
No, it would be “equally useless” only if the person didn’t see any benefit and decided not to send them back for a refund under the 90 day moneyback guarantee. and, of course, it he were to listen to you (and, maybe, even, sign up for your coaching services) he might be $800 dollars poorer (and you $800 richer) and he might not be as fast as he otherwise might be if he took another course. Ugh, do you offer a moneyback guarantee for your services?
Please, please, please, show me the study that demonstrates that “pedaling in circles” (and define what you mean by that term, please, so we are talking about the same thing) is not superior to whatever pedaling form you advocate. I submit it doesn’t exist and if you try to use the Coyle study I might suggest that you actually read that study before you throw it out here as it does no such thing. But, I also suggest you will ignore this discrepancy and continue to claim that your knowledge is superior and we all should just listen to what you say because, well, because, it is you!!!
As a coach, Dr. Paulo, what point of the pedal stroke do you concentrate on when trying to develop power in an underpowered cyclist? Currently I’m seeing some success and improvement by focusing on pushing over the top. The “scraping your foot” over the top of the circle. Thoughts?
"I also suggest you will ignore this discrepancy and continue to claim that your knowledge is superior and we all should just listen to what you say because, well, because, it is you!!! "
Damn, Frank…
What’s that old saw about pots and kettles and the color black?
…I can’t believe I’m sticking up for Paulo.
Let’s drop the “Dr”, shall we? Just call me Paul-O :wink:
IF they have powermeters, I tell them to focus on power. If they don’t, I tell them to focus on riding in the intended zone. I am a big believer in adaptation. The pedal stroke that maximizes power is the best.
Well if, and when, I do the schooling to earn the letters, then anyone that wants to call me Doc, can. :slight_smile:
I do have a powermeter, and the over the top seems to be the key, for now. Lots more work to do…
This thread has excellent potential to turn ugly.
I bought PCs and so far have no intention of returning them. But that’s purely for potential running benefits and the fact that my phys therapist believes they can be useful for hip/ham rehab, which I, sadly, need.
I remain skeptical of any benefit from a more circular pedal stroke, though. And I think too many worry far too much about that.
Are you saying that “the stroke that maximizes the power” will vary between people or is there a stroke “that maximizes the power” that is best for almost everyone? If it varies between people how do you recommend to your clients that they find out what is best for them? If you think there is a best stroke for most people, what is it? And, why do you think that?
Frank
Only if I reply to Frank’s post… :wink:
I thought it a fairly straightforward question trying to get you to clarify what you said. No need for it to turn ugly. :slight_smile:
Frank
Thanks Frank… : )
I’ve actually been looking for an inexpensive set of powercranks for my second road bike. The frame is arriving this week. I’m looking for a set of 175’s or 180’s. Any leads??? I’d love to try a set.
