Still not enought snow to pull a sled.
Thx for responses. Going to go a bit bigger, 45-50ishL.
Rei is somewhat close to me. Heading there on Sat.
Thinking something like this
http://www.rei.com/product/862884/rei-flash-45-pack#tab-reviews
I like the REI Flash 62. Big and light.
I’ ll give you a few tips I learned the hard way:
Do your research
Get the pack weight down
Get the tent weight down
Get the warm clothing weight down
Get the sleeping bag weight down
By doing a bit of research on a lightweight packing forum, I managed to cut over 10lbs in these four areas without losing any comfort (actually my sleeping bag was very uncomfortable, but a silk liner fixed that by only adding another 4oz).
Don’t listen to the gram counting zealots if you’re newish, and doing a 2-night winter trip.
Start safe. With all the safety equipment and layers. Be comfortable.
Going ultralight is a process involving developing a lot of little skills necessary to survive comfortably with minimal equipment. That process shouldn’t be skipped, particularly if we’re talking a cold winter environment.
Then gradually pare down as you get more experienced.
This
This. This.
I like Osprey packs a lot. A first timers minimalist 2-nighter in the winter sounds like a recipe for misery. I hate being cold. I bet you will as well.
winter is the x-factor here. what kind of weather are we talking? if you’ve got 1kg of down in your sleeping bag, 45L+ wouldn’t be too much.
my feeling is that 35 will be too small, but there are plenty of companies doing good stuff in the ‘alpine’-style 45L range.
-mike
I have done several winter ultra cycling events. I like the cold. Much more so than the heat.
Trying them on foot this year. This one is not all that remote.
Definitely not trying to go minimalist.
Coldest bivy I have done was at -30deg F, off the bike. Bag is -20Deg down. Event Bivy, Thermarest pad.
SHTF back-up is Mont Bell down parka and down pants. I’ll have stove (white gas), pot, food.
I have been training to pull a pulk. Dragging a tire all fall, and my pulk when we had snow.
My concern now is no snow, hence the need for a pack.
One of the things I looked for in a pack is the ability to fill the camelbak from outside the pack. On many I found you have to open the pack to access the bladder.
Thanks for the ideas.
Many bladders are accessed from just opening the top lid.
My REI 85L pack (I carry photo gear) has an external pouch that a bladder can slip into, very accessible.
I actually installed quick-connect fittings to my drink tube, and to my filter bag’s outlet tube. The two can join on the trail without opening my backpack, although I do have to lie the backpack face down to take the pressure off the bladder. Maybe quick connections would work for you.
You sound like you have the experience to make this purchase. Experience counts for much in the wilderness. I would just make sure your sleeping bag is sufficient because it will save your life like no other gear item.
If it’s going to be cold, don’t use a camelback. Nalgene bottles w/ a wide lid kept upside down will let you get water out once they start to freeze.
My standard setup on the bike is an insulated camelback inside my shell. Hose run down my sleeve. I’ll go nalgene if backpack.
I recently bought the 3400 Southwest pack from HMG and have been really impressed with it http://www.hyperlitemountaingear.com/ultralight-packs/3400-series-ultralight-packs.html . The most important thing to me was being waterproof and this passes a submersion test (it has evolved since some of the original reviews in 2007 claiming it water could get in during submersion). At 2lbs it really cuts the weight down.
Went to REI and tried on several. They fitted me as well.
Ended up with a Deuter ACT Lite 40+10.
Much more comfortable than the REI flash 45 that I was set on buying. A bit heavier, but I could stand to lose 30# myself.
My boy (A-No) went to the Gopher game with the in-laws, so it worked out to meet there to hand him off.
I originally wanted it due to lack of snow. It snowed last night so I can plan on the pulk.
Thx all.
Just curious where you did this? There are not a lot of spots in the lower 48 that can get this cold. I’m also curious about
what kind of issues you would have with a bike in these kinds of temperatures (and the accompanying conditions). I thought it
was hard just trying to hike around when it was -10F, couldn’t imagine trying to deal with a bike. Sounds pretty epic.
Arrowhead 135, between International Falls and Tower MN. End of Jan.
I am not fast. Lead guys were done. I Needed to sleep.
Special grease in free hub. No hydro brakes. Single chainring up front.
Typing from my phone, sorry for typos.
We routinely bike in the - 40s here in AK. Nothing special for the bike. I really want a fat bike but I really don’t want to spend $2500 on a heavy ass bike.
Edit… JNo is probably right, his bike will definitely survive longer than mine…but it’s a 10 year old MTB so I might convince the wife to get me a new one if I break it.
You boys in AK are the real deal.
I have a Fatback from Speedway Cycles.
I am TOTALLY with ‘trail’ on this!
Everyone will swear by a different base layer, or a different bivy, or even a certain Spork, etc etc etc, all of which will be slightly different in weight, slightly different sizes… If you’re new to adventuring, you’re better to have extra space than need something and not have space to pack it.
Think about the worst case scenario - Something happens to you and you have to stop until help arrives (these things happen).
What do you need to do? Stay dry, stay warm, stay safe! Its amazing how much wind chill can be reduced by plunging your already clothed feet and legs into your backpack and packing your belongings around your legs. A big flap on the top of your pack could possibly come all the way up to your crotch - that will keep important bits warm if it snows! If something bad has happened, you need to save every possible joule of heat energy. I’ve been in this situation and the medi-centre that treated me said I’d saved my toes by effectively “getting in” my backpack.
I’ve since got better thermal kit, which weighs the same, ive got lighter mess tins and stove which does the same job and packs down smaller. All these small things you decide on over a period of becoming more experienced with what YOU need. Forget everyone else. It’s about what YOU need… but if you’re ‘relatively’ newish to ultra-hiking or adventuring, having something that you may NOT need, may end up inadvertently saving your life.
I’m with ‘trail’ 100%.
No lightweight here.
I have my -20deg bag inside my bivy. It’s in my big duffel on my pulk. Worst case I will pull it out and jump in the bag to warm up. I can fire up stove from inside my bag.
Sporks suck. Not a good fork, not a good spoon.
Not sure what you paid at REI, but I just picked that pack up at Sierra Trading Post for $75.00! STP has it for $125.00 and it’s pretty easy to get another 30-40% off of that.
Thanks!!
I paid $169
Ordered it for $99 with shipping.
