I agree with kdw, goal times can be dangerous, find your threshold and ride a percentage of that, but I was not try to qualify for anything just finish strong.
I rode 68% of threshold (due to the heat, 70% was the goal) at IM Wisconsin and averaged 19.3mph (5:50 total ride time), 5’ 6", 140 pounds, 173 np and 168 average power, really low VI
231 watts for 56 = 2:16:xx within three weeks of each other on similarly profiled courses. I’m laboring under the assumption that a watt is still a watt at mile 112, same as it is at mile 56…
Of course, holding it for 112 and running 3 whatever off is the problem! For me anyway…
IMNZ this year, very rough road surface, lots (& lots!) of rain, 1996 Look with clip on bars, Corima deep front & Velocity w/ wheelcover rear, 5’11 & 158lbs. Sleeveless rainjacket which kept me warm thank God
I’d give it an approximate +24 watts to go from 18.8 mph to 20 mph. I figure a watt at your speed is about 1 minute…and about 20 watts gets you about 1 mph…given the same position/equip/course/conditions…
I’m about your size - for IM AZ - I’d need about 170-180 watts to go 20+. Not sure how IMLP compares…but likely need a few more watts for the same time vs. IMAZ.
I am very similar to you, 5’7" 152lbs at LP this year. Rode a 6:08 on 148watts. First lap was pretty good, second lap was shit (25min slower). I was undertrained and was hoping for more like a 5:45 on 170watts…not so much…
I’d recommend a couple of test rides in race setup… no sense to compare with other riders, there are too many differences (weight, aero position, bike gear, bike setup, riding style etc…)
At your weight I’d guess if you rode 180 watts give or take you’d be good. Maybe a bit less on an easy course.
At IMLP I rode 5:25 I think about 20.6mph and that was at 196watts w/ np at 217. I was fat and your height but 185lbs. I also mismanaged my ride horribly in my first…as you could tell from the VI.
That’s with a powertap, if you had an SRM or Quarq at the crank maybe add a few watts.
I am new to power and just acquired my first Powertap. I did my first light spin on it tonight before a loose crank forced me to stop spinning. Anyway, looking for a quick answer from those of you who know and can give a quick answer. I am 5’8", 155lbs. I have ridden 18 and 18.8mph average in my last two IMLP finishes. Wondering what I would have to hold for an average wattage to sustain a 20+ mph average over my next IM bike leg attempt. Thanks for any insight.
IMNZ. 5’11" / 72kgs/158lbs. Rough roads, rained all day, wet weather jacket/arm warmers etc etc…
19.5mph on 167 watts.
I’d say 170-190 watts depending on your position and the wind conditions. There are so many parameters to take into account tho. Shoot for that as a target. If you have an FTP over 250 watts you should be able to accomplish your goal.
About same size as you and on Computrainer I average around 216 watts for 56 miles. It might gor up a bit as that is with warm up and holding 222-230 for most of ride
