AutoCad Question
Ok, I am sitting here t work late night trying to figure this out. I have a background from an architect, once I xref that background into an issue file the light disappear. They appera fine on the original background drawing. When I select one of the light they are listed as a “masked reference”. I trried editing it, nothing. Basically I need to know how to view that masked reference in the issue drawing that I have created. The only way I can view the lights now is if I explode them a few times. They are not masked by the RCP, tried erasinf it, the light still would not show.
Help. I tried asking some of the CAD forums, no answers. Hey maybe tri peole will know.
Paul
What version? What exactly are you trying to do?
~Matt
I’m not 100% sure what you’re refering to or if you’re using a version that I’m familiar with. However from the rough description you gage sounds like either A) you have conflicting block names or B) an unavailable file(s). I’ve never seen a “masked reference” error so not exactly sure what that means. However if you have existing blocks in a drawing and insert or Xref similar named blocks the old blocks will look like the existing blocks. In this case if the blocks in the drawing were the same name but contained nothing, the lights would disappear on insertion. Not sure if that applies in this case or not.
Also sometimes Xref’s links may get broken or the files may not be available, but usually that gives some other error. I don’t do a whole lot with Xref’ing nor am I real familiar with the architectural Acad so the above may be entirely innaccurate for you software.
~Matt
ABS 2007. All I am trying to do is the xref the file I got from the architect into my new file. When I do that the lights disappear. When I called the architect, they told me that the lights are are masked block, or a masked block reference. They should be viewable as I am referencing them into a file that has nothing in it.
The architect also created his drawing in ABS 2007.
Well apparently in ABS there is a thing called “Masked block”. Here is some info in a discussion. LINK
Not familiar with ABS or masked blocks, but this looks like it mat do the trick.
Re: Ceiling Grid Masking
I draw a poly line around the light fixture and use the ‘add a hole’ command
in the ceiling grid.
highlight the grid, right click, clip. type a for add hole, select grid,
select poly line.
Sounds like it takes alot longer than it does.
k
Sounds like masked blocks are blocks that respond to being under or over other certain masked block layers. Apparently as you Xref the file in it messes with these layers. Not being familiar with these or ABS the following is merely a guess. I’d say you need to figure out how to either change the block mask order or simply put in holes as is described above.
Maybe to little to late but I hope it helps.
~Matt
