Asics Kayano 15'$$ or?
First running shoes I purchased were not right for me, (Pearl Izumi Peak XC’s) - causing some shin splints and knee pain. Got check out and I have been told I have a slight over Pronating (especially in my left foot) - pretty normal arches. It was recommended that I get a more structured shoe with some cushioning. I tried on some Asics Kayano 15’s and the felt fine on a short run in the parking lot area, but no real way to tell until I get some miles on them, but at $125 I’m kind of hesitant to spend that kind of $$ on a shoe I have no idea if it’s really going to help much. The bike shop I ride for can get me at least a discount on Pearl Izumi’s, but I don’t want to make the same mistake twice. It looks like in the PI brand the SyncroGuide II and the SYNCROINFINITY are about the same type of shoe as the Kayano 15’s.
Any recommendions on shoes that could be a bit less expensive or am I better off spending the $$ on the Kayano 15’s and “hopefully” be done with it?
Michael
I believe Kayanos are for more than slight pronation. 2140 shoes are cheaper and not quite as controlling as the Kayano. Probabably the most popular shoe around.
http://www.asicsamerica.com/products/product.aspx?PRODUCT_ID=240012112&TITLE_CATEGORY_ID=250001542&PARENT_CATEGORY_ID=250001538
Buy a year membership to road runner sports. You can return shoes even after youve run in them if they arent right for up to 60 days. I buy almost all my shoes there.
Do you have any good running stores near you? Shoe fit seems like it’s largely ignored around here, but it’s probably as important as good bike fit.
My local store does video analysis to help determine which shoes are best for you:
http://www.transportsrunswim.com/run/SportsMotion.html
That’s the best choice if you can find a shop near you.
If those are your first running shoes, I’m thinking that although the shoes possibly contributed to your injuries, there is also a good chance that being a new runner may have contributed quite a bit as well. Whatever pair you do end up buying, try rotating them in with the PI’s that you already have and keep in mind that you will have to buy a new pair every few hundred miles or you will keep getting injured.
The Kayano is to the running shoe industry what the Hummer is to the auto industry.
Neither should exist.
I ran in Kayanos for about 7 years until the 13’s. I bought a pair of mizuno wave creations at the start of this year and I am never, ever going back to kayanos. Do a search on the forum you will find many people that have the same experiance.
The Creation and Kayano were not designed for the same purpose. The Creation’s existence is probably justified, though.
those are completely opposite shoes…
It’s probably too much to spend, because your knees probably aren’t worth $125.
-Jot
umm, no they are not. you are looking at two neutral cushioning shoes.
yeah, um, NO…the Kayano is NOT a neutral shoe. The post on the medial side of the shoe clearly indicates it is not for a neutral runner…the Nimbus, or better yet, Kinsei are the top Asics neutral shoes.
It amazes me how clueless the typical triathlete is regarding running and running equipment. This forum is an epically bad place for information.
Of course, I’m here to lust after the Bike Pjorn and read Tibbs’ Purple Palace.
although I cant jump in on the shoe debate. Kelly’s Running Wharehouse has the Kayano for $107.00. If thats what you decide to go with. I have run in them for about 400 miles and have not had any problems. I use them for my long slow runs, for what its worth.
I second that. I had shin splints all the time the first year of running, going from couch potato to half marathoner in 4 months. They looked at my “pronation” and decided I needed orthotics, and I was slow and injured all the time until I just started running in light neutral shoes all the time. Nothing heavier than my NB 826 or Zoot TT. This is my first season without shin issues. If I even use moderate stability I get shin splints as it forces me into unnatural heel striking.
Give yourself time to build up, avoid speedwork (stick to tempo/progression runs), and avoid uneven surfaces.
Correct you are, hence the reason I will never wear them again. Kayanos are way more shoe than I needed.
Man how I wish my problem was bike related (road or mountain anyway), I know about bike stuff. This running side is just way too confusing. Getting opinions from all sides of the fence??? I still have no clue :slight_smile: I figure you’d just thow on a pair of comfortable shoes and go for a run - no idea there was a possibility that I could end up buying a dozen different shoes before I may find one that doesn’t cause some sort of pains.
Good informations and at least I’m learning something
Michael
Ask the runners in the area to get an idea of the best running store in the
area. Then go to that store and have them help you.
In Phoenix, Performance Footwear is that store. In your area, only the runners
know. :slight_smile:
-Jot
um, it shows up as a neutral shoe in running world.
http://www.runningshoeswizard.com/asics-kayano-13.html
Any good running shoe is going to be $90 to $100
An extra $15 to $25 one time may be worth it to try them out.
jaretj
