Argon E118 Paint Replacement
So I had a bit of a crash this weekend which resulted in scratching some of the paint off the frame (cried all the way back to my car)…
Does anyone recommend how I can get a paint repair kit for this bike? Here’s my bike: https://www.google.com/search?q=argon+e118+paint+repair&es_sm=93&source=lnms&tbm=isch&sa=X&ei=vl5VU7elFoH22QXb5oC4Cw&ved=0CAsQ_AUoBA&biw=1733&bih=992#facrc=_&imgdii=_&imgrc=G65GpQBibrMy2M%253A%3BfpKfVHG9tkQnPM%3Bhttp%253A%252F%252Fwww.jackandadams.com%252Fdir%252F2824%252Fimages%252Fsite%252FE-118_Dura-Ace_C75_A18_2013_white_background-1024x685.jpg%3Bhttp%253A%252F%252Fwww.jackandadams.com%252Fabout%252Fbike-brands-we-offer-pg69.htm%3B1024%3B685
Cheers,
CK
Depends on your definition of “some of the paint”. If it’s just a few small scuffs you can probably get some touch up paint at an automotive store. If it’s larger and requires actual paint prep/work Hot Tubes is usually recommended. If it looks like there maybe frame damage Calfee does a bang up job (no pun intended)
If you can post photos of the damage, that would help assess the situation.
If you want to see what professional bicycle chip repair looks like, Google ‘professional chip repair bicycles’
