Sigh - this weekend was a bike maintenance nightmare as all 6-bikes in our garage got some TLC (or PMCS if you prefer). Unfortunatley on Sunday I ended up spending the better part of 3.5 hours trying to modify a set of Syntace Space Control brake levers so that they would fit into the end of the bar on a new Vision Tech Integrated Pro aero bar. Of course only after a lengthy bit of filing and sanding that (A), the Vision Techs are drilled for use with brake levers that use an external cable run, and (B) the bolt/cable guide that the brake cable runs through in the Syntace brake lever is aluminum and the threads are easily stripped if you are not paying attention - &#$& (grumble, grumble)! So now it is Monday and I have to decide on replacements - either Vision Tech’s nifty 1-finger brake levers (there are a set installed on my wifes TT bike) or the Cane Creek 200tt brake levers which while less expensive, the compression design may not work with the bars either. Anybody need a set of used Syntace Space Control brake levers?
