Are Scott aerobars compatible with Bar end shifters?
I’m looking at some old Scott aero bars for a cheap tri-bike build for a friend. I am wondering if the ends of these are the correct diameter for bar end shifters? I’m referring particularly to the Scott bars that come in two seperate pieces and that many people rode using the bridge that bolts the two together.
Anyone?
Thanks
sweet
I did use bar ends on these at one time but i had to take 1 or 2 of the 4 expansions joints(?) (not sure if thats what they are called) to make it fit … it worked fine though!
The barends wont fit in them. (lemond clip-ons) You will have to use a 25/32" or 20mm drill bit to make the ID bigger. I did it once and its not really worth it. Scott made a special bridge to mount downtube shifters on. Get some used Profile split seconds on ebay-- A much better product.
BJ
I have a set of Syntace Streamliners I’ll sell you for $20. They are size large, but I cut about 1 1/2 inches off the ends so the barend shifters fit right in your hand, so you won’t need to move to shift. Let me know!
I have both the Scott LeMond bridge and a Profile bridge that will let you put “down tube” shifters (wow…I said down tube shifter) on those bars - you are welcome to have the bridges for free just to get them the hell out of my house.
see my post above … they DO work with no drilling the last time i did it.
