Are all fluid trainers created equal?
So I’m in the market for a trainer and, based on the living situation, i’d like one that is quiet. After shopping around, the prices for fluid trainers are all over the place (definitely want a fluid, not mag). The cycleops fluid trainer is $250-300, while the nashbar version is $120. will the nashbar trainer perform that much worse and fall apart that much sooner? Any input is welcome. budget says go with the nashbar version–what do you guys think? I would be using it for 2-3 rides a week, but my long rides will be outdoors.
It’s hard to beat those Kurt Kinetic trainers. They are pretty nice. Quiet, smooth, durable, easy bike in and out.
I sell 200 Cyclops trainers a year but I still like the Kurt Kinetics best.
i was reading up on those and they are pretty sweet—but unfortunately you gotta have some serious $$ to grab one. i’m sure it is well worth it, but i gotta save up for some other bike upgrades in the spring. i guess that’s why i was looking at the nashbar one–i always read the bikesport michigan reviews first and saw how much you liked the cycleops, but i think it’s a tad outta my price range too. do you know anything about the lower end fluid trainers? are you really getting what you pay for? do the nashbar/lower end ones leak?
I just got the Cycle Ops fluid 2.
Its very quiet indeed, no problems there. The assembly instructions are not idiot friendly, putting it together took a while and there are only 4 pieces. The legs are supposed to extend to help level the thing on uneven floors, but mine won’t budge…nothing a magazine doesn’t fix.
I like it…but can’t compare it to any other models. Its my first one.
legs don’t extend… i just looked at mine…
but i second the cyclops… i’ve had mine for 2 years… no problems whatso ever, and i do alot of summer biking on it… (its only because where i work during the summer, roads arn’t safe to bike on)
  • highly recommend it!
    david
if you look hard enough, you can usually find a used cyclops fluid for $100 or so. check ebay, slowtwitch classified, etc.
I have three trainers and a set of rollers.
Two fluid trainers including a Cyclops and an Elite - I prefer the Elite because of the spring tensioner whereas the Cyclops is a screw mechanism that I have to adjust as my tire gets worn. Plus the guys I train with like to f*** with me and increase the tension on it.
I picked up a Tacx Mag train with the power meter this year. So far I like it quite a bit. In fact, I cannot tell the difference between this and my Elite Trainer. We’ll see how things are going in a few months.
My rollers are Kreitler Rollers. I’ve had thes for quite some time, but they sure help my bike handling skills. The best part is that my tires turn silver after each ride.
I cannot remember exactly what I spent on each, but I know I spent $30 on the Elite as it was considered salvage. The Tacx was around $300 and I think I paid somewhere around $200 for the other trainer and my rollers. If I had to choose just one I’d go with the Elite. The key reason is the spring tensioner and the other reason is that it is easier to transport (marginally so) than the others.
Good Luck!
Rocketboy
Dude - Take a look at the Kurt Road Machine. Gottaride bikes.com has them for $275 less 20% for your first order AND no shipping fee.
http://www.gottaridebikes.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=TRN0001&Category_Code=TRN&Product_Count=4
Just bought one…
Tom,
I have a 2 year old Cyclops today. Is the difference enough such that you’d recommend someone switch to the Kurt Kinetic?
My complaints with the current trainer: The frame is not 100% true - my bike does not sit vertical, and I need to shim one of the legs to deal with this. \ It occasionally gets noisy once the fluid unit gets warm. The trainer has done this from the first month that I’ve had it. (This is not the tire to drum interface squeaking.) I need to swap out my quick release and use the one that they supply. (Usually not the biggest deal, but a pain when warming up before a TT. I’d rather not use that cheap heavy quick release come race time even though it won’t make a real difference) I really need to adjust the clamp so it is really tight. Otherwise the bike wobbles just a bit.
Also, is the Kurt Kinetic any quiter or louder? They also rate it at up to 3000 watts vs. the 750 for the Cyclops. Is this real? If so, I would think that you could do some sprint effort workout that can’t be done with just 750 watts.
Thanks,
Joe
Actually, I think the Kurt Kinetic may address each of those issues. Across the board it is a nicer product.
The Cyclops is good, but it is for a person who rides a trainer once or twice a week. The Kurt Kinetic can be used constantly and will hold up well. We use them to fit people on now which means 4-8 bikes per day going into and coming out of the trainer 6 days a week and our bikes in there on Sunday.
No, fluid trainers are not created equal. There are a variety of design differences that are significant in how you want a trainer to feel. I’ll mention here that I’m a rep for Kinetic - but I’m also a serious cyclist and gearhead.
With the introduction of our power computer, we had to buy our competition’s trainers and calibrate them for our computer. So, naturally, we put them to the test to see how each one performed on our test robot - basically a 5Hp motor hooked up to the bb of a trek 1400. Here are some objective notes on test runs.
The CycleOps’ force curve was the second most accurate, next to ours and made it through the test (700 watts) without leaking. However, I now know why CycleOps rates theirs at 700 watts and not a bit more. At about 27mph, or 725 watts, the unit runs so hot (225 degrees taken with a laser temp probe) that the internal driveshaft expands enough to seize itself, making the wattage jump to 1500 watts at the same speed. This was after holding 700 watts for 10-15 seconds, which a good rider can do.
The BlackBurn did not fail, but it does not produce agreat deal of resistance. Only 700 watts at 35 mph, 93 @ 20 mph. It’s force curve is pretty much linear.
The elite/performance fluid ALU was even worse in terms of generating a lot of resistance, but it is most likely die to the spring mechanism that holds the roller to the tire. At high speeds/fast accelerations, the spring is not enough to avoid tire slippage. This one would be bad for intervals, but it’s only $140.
1up didn’t agree to test, so I have no data.
The Kinetic had the lowest operating temp (120 @ 21 mph and 155 @28 mph - deep in mind that the Kinetic also produces more watts at those speeds than most others). It was also the only one to record and sustain without issue a watt reading over 1000. I’ve tested a few of our units and have routinely sustained 1700 watts for mintutes and spiked them at 2700-3000 for no more than 15 seconds. Running @ 2700 watts for sustained periods will heat the unit to the demagnetization temperature of the magnetic coupler, and cause it to slip. No failure, no leaks.
Beyond that, go out and ride a few trainers. Some feel like crap. CycleOps, Kinetic, and 1up are generally regarded as the best feeling trainers. No one else has as significant of a flywheel as us, so if you want a bit of coast down, we’re the only way to go.
From a design standpoint, I think ours is superior. Our magnetic coupler eliminates a dynamic seal, so there are no moving parts touching the seal. EVERY other fluid trainer has an o-ring wrapped around a driveshaft to seal the fluid. We also use silicon fluid, which does not expand - good for leaks - and does not lose viscosity while heated - good for your workout. We work on our heatsink, rather than adding a cooling fan like CycleOps (this cooling fan is responsible for 1/3 of the resistance on the Fluid2).
