Okay, Chad has me thinking. His experience on 20mm tires are pinch flats and rough ride. I sure do not want any of these.
So, before I put 20’s on my new Zipp 808 front, what are others using? What has your experience been? Anyone have any data
on how much faster one became from going from 23’s to 20’s?
Everybody is different, but I personally have had much better experience (overall, taking in all factors) with 23mm clinchers. I tried 20mm for a short while, but went back to 23mm and that’s what I’ve continued to use for years.
Stick with the 23’s. Actually, I think the Zipps were made to work with 22’s anyway for optimum aero benefit. You can guarantee a decrease in ride (and possibly increased risk of flats) with little to no increase in speed.
I did some searching and was reading comments on tire size and tire pressure. This site is great.
Was interesting I crashed at vineman running 20’s and 140psi.
Seems clear the majority say stay wtih 23mm, which I will now cancel my order for 20mm tires. And, seems like staying with 120psi on my MP2 tires
again seems to be the majority opinion.
I have raced on 23 and 20 for 20 years. Unless you are a porker, pump the 20 to 125 lbs of pressure. Yes is might be a harder ride but you are in a race not a Sunday touring ride.
Yup - one of the easiest speed decisions you can make: 23mm Michelin ProRace2 clincers to 120. Fuggedaboutit and done. Worry about something else now, like water bottle placement
Check out the new Zipp clincher tires on their web site. They are actually 21’s and are designed around the rim width of Zipps. Seems to me to degrade the performance of your race wheels by sticking a fat 23 on their…at least in the front. They are made by Vittoria and are pretty damn expensive but Zipp claims they are the fasted tire for their wheels.
I’ve used 19/20mm tubular tires for race day tires. 23mm is for everything else. You do notice a difference in comfort, which wasn’t important to me in sprints, but for longer events it adds up.
Actually I’m now mostly riding on 22mm Veloflex Black clinchers.
The recomendation for 23mm clincher Michelin ProRace2’s was a good one.
I just listened to a podcast recently (can’t remember which one) where a representitive of Bontrager said that their aero wheels are made for use with 23mm tires. He noted that if you use 20mm tires you are exposing the little rim lip to the wind and it ruins the wheels’ aerodynamics. I’m not sure if the same applies to Zipps, but it seems reasonable that a similar effect would result. I’d check Zipp’s info and follow their reccommendations.
I just wrote Josh a message about his thoughts. When he wrote me in July, the new tires were not around.
So, I am wondering what his recommendations are now.
