Anyone using the HED 3rd brake?
I ordered one of those HED 3rd brake levers today. I am planning on mounting it on my left side so I can brake and shift at the same time (if I have to). The dilemma that I have is which bake to run it to? Any thoughts???
Thanks,
Jeff
I’ve often thought of buying one, but haven’t gotten to the point of actually ordering it.
I actually don’t know which brake the pros use it on, but I would use it on the rear brake; if you ever get to the point where you have to brake really hard with that brake, I would be concerned about “tipping over”.
I have one. To answer your dilemma, if you mount it on the left side, wouldn’t you want it to be the same as your left brake lever now, which is the front brake. To the right side, that’s your rear brake.
If you mount it on the left side but make it go to the rear brake, wouldn’t that be confusing as you have one brake lever on the left that goes to the front, one that goes to the rear???
(Maybe I didn’t understand your question but the answer seems obvious to me).
I already ordered the one for the left side anticipating running it to the front brake. I was wondering if anyone has done that with success. Since more of your weight is over the front center of the bike and I figured to would do a better job there. I also figured that since it is split and will have less power, it would not help much on the back. I do not anticipate grabbing it in a “panic mode”, so I am not worried about that.
So, has anyone run it to the front?
Thanks,
Jeff
There’s a guy named Gary Tinley (I think that’s how to spell his name) that has done that. He posts here so he might chime in.
There’s actually a thread on this very subject where we were talking about this product and he gave a review on it. And again, his is hooked up to the front brake.
Thanks auto…I found the article. That is exactly how I was thinking about setting it up. It looks like someone else is as crazy as I am hooking it up to the front!
It will help me to do some pretty cool nose wheelies!!!
Jeff
definitely on the front, you’ve got gobs of traction on the front wheel with all your weight on it. It would be way to easy to lock the back wheel up and the back doesn’t have much power anyways (due to the weight bias especially when decellerating). The back would just be a recipe for disaster going into a hard corner…
I did a photo shoot last week where we were riding right on the bumper of the photo van in aero position, well I was on a road bike the other guy on a tri bike. I was able to secretly feather my front brake the entire time to make it look like i was working hard and keep the bike in the right spot (riding like 2 feet off the back bumper) and I kept thinking my tri friend would probably sure love to have that 3rd brake lever right about then… If you ever want to have some fun, try sprinting out of the saddle behind a van going 20 mph, that’s right only 20mph and you’re in a full standing sprint covertly clamping down on the brake that’s on the opposite side of the camera shot, fun resistance training!
I have it on the rear brake now, as I run a Hooker on the front
I primarily only use it for TTT
Hello Jrob and All,
I had one, used it for awhile, and took it off.
When training where there is traffic, I found that when I needed to brake I usually came out of the aero position for better control and to look around.
It seemed like a good idea at first but I decided it was just something else to maintain and did not help that much - simpler seemed better.
As an old aircraft designer used to say - ‘Make it lighter and simplicate’
Cheers,
Neal
I used the 3rd brake lever last year & it worked for me. I used the right hand mounted lever & ran it to my rear brake. I would not recommend hooking it up to your front wheel.
However, one of my dealers that orders quite a few is buying the left hand version. I voiced my concern about using the levers on the front only & they explained they were hooking up the left lever to the rear. Their logic being that there’s a lot going on with shifting gears on the right side while bleeding speed off & then accelerating. Makes sense to me. I’ll try it this season & see how it goes.
Still have it on the rear brake - makes the regular brake very “mushy” so I put it on a less important brake. Use it for slowing down only - think that was the intention - bleeding off speed. Comes in very handy in emergency situations when in the bars and something gets in front of me - and I can still swerve to avoid. Also has been nice in the couple of group rides I’ve been on with my tri bike.
sane people (aka “brits and euros”) have the left lever connected to the rear always. there is one small category of insanity that goes for that as well - cyclocross riders, who appreciate being able to dismount with their hand jamming the brake lever and not finding that as they unweight the bikes does an endo.
its just Better In Every Conceivable Way ™.
jrob,
As Speedy and others have suggested, the rear brake is the brake of choice. Here’s why.
When you apply your front brake, you lose most of your ability to change your line or steering and you generally proceed to travel in a straight or straighter line until you begin to release your front brake. You regain this ability to steer as you release the front brake.
Now normally, when you are speeding along, it is not necessary to slow down when traveling in a straight line. Only when you are approaching some kind of a curve or turn and you wish to take off some speed to better negotiate that turn do you apply the brakes. Only trouble is that if you only have one brake to do that with and it is the front brake, then you have compromised your steering control just when you need it the most!
You want the 3rd brake lever to control the rear brake. End of story. That’s what the pros do but this is the reason why.
Hope that helps.
Just curious, what’s a “Hooker” on the front, mean?
Ben,
Thanks for the advice, but I am going to run it to the front. I am pretty comfortable with my bike handling skills - I have done a lot of racing both on and off road. Besides you are supposed to brake before you start the corner not while you are cornering.
Jeff
I don’t see any problem with mounting it on the left, but definitely run it to the rear brake.
The idea behind an aerobar mounted brake lever is not stopping power (where the front brake is key) but speed control where the rear brake is effective with our compromising handling or steering control. If you need to stop, you need to use the front brake, but you also need to get out of your aerobars.
I had one for the majority of last season and loved it. Only took it off as it was a routing problem with the new bars I got (could either keep the lever and have cables all over the place OR hide the cables and no lever).
Mine went to the rear, never really thought of routing it to the front.
In any case, I really liked it and miss it.
Hooker: http://www.slowtwitch.com/mainheadings/features/hookers/hooker.html - you can see a bit of the front brake in one of the pictures, it’s like (is?) a Campy Delta brake.
-Chris
