Anyone upgrade from P2C to P3C and comment if worth it?
I have a P2C and love the bike. I am 6 feet tall but have a 35" inseam. So longer legs than torso.
I have been toying with upgrading to a P3C. Like to get others opinion. Worth it?
I included info on my build because I read somewhere that the P2C fit short torso people better than the P3C.
Went from P2C to P3C within the same season but not back to back. I definitely prefered the P3C because of fit. I do have a longer torso proportionally, is just fit like a glove-no spacers either! Fit was the primary reason I switched.
Upgraded from P2C to P3C this year, primarily because of a deal that I can 't pass up. It was a 2008 model with upgraded components all around, and I love that color scheme. I honestly think that the fit are almost identical, unless you are already riding with zero spacer in your P2C, then P3C will give you more of an aggressive position, otherwise, with spacers and different stems, you can pretty much make the fit identical between the 2 bikes. For me, I ride a 54cm, and the reach of the P3C is just a tad longer and I find myself riding just a tad lower. I prefer my new position on the P3C, and it feels more (unscientifically) aero to me.
All in all, no regrets at all. The look and the color alone is worth it for me. :slight_smile: Not to mention that it’s a faster bike than the P2C - at least psychologically.
I ride a 51 p2c…same exact geo. to the p3c but only in that size. So for me it really made no sense to “upgrade.” For whats is worth I have ridden the P3C for about two weeks in the same size, exact set up. All that I really noticed was that the P3 was slightly stiffer. In terms of fit in the larger sizes, unless you have the sort of setup where you have your stem on the headset or with one or two spacers under, claiming the P3c “is a better fit,” is just B.S. If you just plan old want the P3c just get it.
