Anyone tried the new Carnac TRS9 tri shoes (yeah the really really expensive ones) with the silver carbon soles. Or the Specialized Trivent shoe or even the Diadora two strap carbon shoe I’ve seen around?
Looking to replace my Shimano tri shoes with somethign more fun. Bang for the buck buck the Specialized is winning but the Carnacs sure do look cool. Carnac pic is at www.all3sports.com but there was a euro carnac site that I can’t seem to find now.
I just got the new Specialized Tri-vents to replace my Shimano TR-01s. I’ve used them on my trainer once, and I quite like them. My feet tended to get numb on with the Shimanos on any bike ride that lasted more than 40 mins. The tri-vents have a slightly larger toebox which makes them nice for me as I have a wide toe box.
I couldn’t seem to get the Shimanos to work for me. I did get some tingling in my toes with the Specializeds, but I could move my toes more in the new shoes which helped. My coach recommends changing out the shoe liner as a quick fix. I’ve not heard of others who’ve had similar problems with either shoe. If anyone has ideas, let me know.
“My feet tended to get numb on with the Shimanos on any bike ride that lasted more than 40 mins.”
I have the same problem, but I haven’t worn them enough to toss them! That and the strap is all wrong. The joint between the hook and felt on the velcro is about 1 mm from where I’d like to pull the strap, so the metal loop hangs up at that point and the shoes are loose on my feet. If I give an extra tug, they end up too tight. Either way, numbness ensues…
I’m taking a serious look at the Garneauxs and the Carnacs.
the strap issue sucks and my roommate has the same problem. I solved it by taping a piece of 3mm neoprene which is strap width by about 1.5 inches onto the strap so it sits under the strap and on top of the tongue. This tightens the shoe fit up a bit and now I can snug them up in races just fine. Also taped off a portion of the velcro so they wouldn’t get velcroed closed while riding with my feet on top of them.
My girlfriend has the Garneaus and likes them. Plus they are cheap.
But those new Carnacs look sexy and fast… Although if I’m in that range I might as well jsut get the Sidi T-1 carbons…
If they fit you well, they’re a nice shoe. Carnacs have a build up on the inside edge that works a little like Le Wedge. That part interests me.
I’ll try that thing with the strap, but I’d still like to jetison the shoes, because I also get the numbness, but only in one foot. I wear Sidi Energys for long rids and like the fit much better.
funny, my roommate who I just moved in with, complained to me before our ride this morning about his Shimano Tri shoes as well. Do the new Carnacs have the medial build up I wonder? They have gone from thier carbon thermoplastic soles to carbon fiber/epoxy soles now like most of the industry. The new shoes look really nice but so do half the carbon soled shoes out there. I agree though the Shimanos have a pretty sloppy fit and the upper material could be thinner as they hold quite a bit of moisture in the heel cup if you get them wet. For the price they are pretty nice though. The new Specialized look pretty nice for the $$ too.
I have the shimanos and I changed the insoles to the thin moldable sole footbeds which helped snug up the fit. Also, I moved my cleats back a little to alleviate some pain I had with them.
I just raced 1/2 Ironman Mexico with the new Specialized shoes. they were great. Easy to get on and off in transition. No socks comfortable. Feet stayed nice and cool. Silver colored carbon soles to reflect the heat. actually it was 102 degrees so it was pretty hot. I would highly recommend then
