Does Vittoria pitsop work with a disc wheel? Anyone tried it with the “bong” disc adapter thingy? How about the Hutchinson “SpeedInflate” product.
Yes. It works, but it is not a 100% thing. If the alignment of the disk inflation adapter isn’t right when you cut loose with the pitstop you are going to have a mess on your hands. Literally.
No. But my n=1 attempt on a regular wheel with butyl tubes after asking Vittoria directly for directions was a complete failure. It just came out all over the place - out the hole - out the valve - never sealed. Did not work at all. They said it works with butyl tubes.
I’m not planning on trying again after reading the other posts.
Dave
PitStop doesnt work at all. I tried using on a butyl tube that I poked a pin hole in, and it didnt even fix that. Maybe it was because %80 of the contents of the can sprayed out everywhere instead of going in the valve. I run Stans in my tubbies and dont worry about flatting.
Did not work for me. Same result as Dave. Tom seemed to have better luck.
