Anyone had patellar tendon tear?
I went to ortho a few months back and found out that I have a patellar tendon tear (~50% of cross section pulled away from lower edge of patella). Apparently it requires surgery and is past the point of doing only rehab or injections. I saw two different specialists and both were surprised that I was in any real pain. I’ve had very faint pain right below the kneecap off and on for well over a year now (that’s why I finally requested the MRI). Steep bike climbs and long/hard runs tend to make it sore afterwards and squats, lunges and other deep power leg movements cause sharp pain. However I can usually swim, bike and run with relatively little to no pain during the actual training session. I already put off surgery a few months to get in my A-race for the year and am set to have it at the end of the month. But part of me is starting to wonder if I’m doing the right thing. I hear horror stories from different people about how they have continual pain after the surgery. And since I don’t have a huge pain problem yet, should I put it off or am I risking a full tear?
I’m set to have artho to remove any scar tissue and 1" front incision to tack tendon back to patella. Rehab appears to be:
– Swim with buoy after 2 weeks (sutures out), no turns
– Swim with flutter kick after 4-5 weeks, no turns
– No resistance spinning on training after 4-6 weeks
– Treadmill walking after 4-6 weeks
Then go from there with small resistance increases. Regular training at 3-4 months out.
Does anyone have any experience with the surgery and/or rehab? Thanks.
Chaz - while I certainly can’t tell you what to do, patellar tendon tears are pretty uncommon an if I had what you seem to have I’d have it fixed the very next day. I wouldn’t risk turning a partial tear into a complete tear…a career ending injury in some. But that’s just my take.
And, in my hands, the incision would be larger than an inch!! Good luck.
I had a patellar tendon tear (partial) about 18 yrs ago, but it did not require surgery, just a lot of PT and anti-inflammatories / icing. I had “overbuilt” my quads during dry-land ski team practice in college (lots of plyometrics and lifting) and slacked on my stretching-- that resulted in strong, powerful, yet SHORT, quads. When I upped the intensity in the plyometrics, the short quads pulled my patella up onto the rough part of the femur, abrading my patellar tendon and patella in the process. Basically was sanding down the tendon and kneecap!
It wasn’t a complete tear but I did have to:
  1. stop for about a month
  2. take anaprox (prescription Aleve before aleve was OTC) for inflammation
  3. ice 2x 30min. daily directly on knee
  4. 8 weeks PT- stretching, motion restoration (ie BAPS board), resistance training (bands, Biodex machine, etc.)
The basic approach was 1) take care of the inflammation first, as I was told healing won’t happen until the inflammation resolves (hence the anaprox and icing.) I’ve continued to use that advice for subsequent injuries (other knee medial meniscus tear, shoulder separation, etc- ski racing’s a bitch!) and I think it’s helped. 2) Once inflammation is down, restore range of motion and then 3) rebuild the damage using resistance, and be serious about it (work till ya puke…)
At the end of it, I was healed and actually stronger than before the injury. I guess having a militant PT literally yelling at you from a foot away is good motivation to give 100%
It sounds like you most likely have a more serious injury than I did, so I don’t know if the above helps. One thought I have is, why not try PT and see what happens? Best case, you improve- worst case, it tears more. With the surgery, they’re going to cut it anyway, so what do you have to lose? Surgery’s not reversible, so I’d explore all your options beforehand. In the mean time, I’d ice your knee for 1/2 hour after every workout (no harm in doing that). A good way to do that is to buy the little dixie cups and fill a bunch with water to freeze in your freezer. Once frozen, peel the cup back in a spiral as the ice melts. When it’s gone you’re done. It kinda sux at first but once your knee is numb no worries.
