This is one of the reasons I poured a concrete patio. Guaranteed to crack and it won’t blow away.
I did just finish a flagstone walkway that was sort of like that. Of course, I wasn’t really that concerned about how level it was since it was flagstone. And I left the gaps big enough so that I could fill in with 21a. It is rough and rustic but that is what I was looking for.
Good job. You probably have shoulders like Hercules now!
Can’t do concrete. I have utilities running under the patio and I have longterm plans to run a gas line out from the house to my soon to be built outdoor kitchen. Pavers are easy to lift and replace, concrete is a beeotch to cut and patch.
1. After you’ve marked out your boundary and start digging, stop, take a step back and fill it in. You only need to go half as deep as you think.
Or, call the guys at Pioneer Landscape materials to bring 10 more yards of sand. Loose sand. Forget the bags… We did a 500 ft2 covered patio a few years back.
Sounds like you over-dug. Did you stake it out and run a string line and level it first and then dig to a uniform depth below the leveled stringline? There are specs for how thick of a base layer you need, and the materials should be readily calculable from that, plus or minus less than 400%.
But that kind of work is a good argument for the immigration amnesty bill.
Cant do a dump truck delivery because its in the back of the house and there’s nowhere to drop it unless I tear out a fence and cut down a couple of trees.
I did dig too deep, but better that than not deep enough. I have bout 5 inches of compacted foundation (baselite is gravel, crushed brick and some sort of bonding mortar that holds it all together when you damp it down) 3-4 inches would have been plenty.
Got my pressure treated lumber borders in and they’re level and I have a 5 degree slope away from the house.
I did screw up my pattern and had another15 sq ft of pavers in before I noticed and I ain’t tearing them out.
Damn my knees hurt putting those suckers down…no running for me for a while.
