Any tips for installing SRAM TT shifters?
Looking for any install tips- particularly for the front derailleur shifter.
The lever for the front does not sit in he same spot as a Shimano and seems to have really short pull.
You need to run SRAM derailleurs with the SRAM TT levers. As you mentioned the cable indexing length will not match Shimano derailleurs.
Shane D
They are SRAM derailleurs.
As I said, the front shifter positioning and travel is much different form the Shimano.
I am wondering if there is any way to set the front shifter up better.
Mine have a very short throw required to shift the front as well. I’m very competent with mechanics and working on cycles, but double guessed myself on this one and took it to a really reputable mechanic. It came back exactly the same.
