Any of you MTBers have an opinion about QR15?
Deciding on a fork (Probably Fox F100 RLC) for my hard tail (Titus Eleven).
A QR15 front axle is an option, but the cheapest (2010 and 2009) I can find is about $150 -175 more than regular QR (2009)
I have a hard time believing the supposed additional stiffness is worth the $…
Any opnions?
FWIW
My FS has regular QR and I would like be able to exchange wheels.
Some hubs allow you to switch between systems (hope, mavic) not sure how much hassle that is…
Ron.
If you want to be able to exchange wheels, I would say go with the regular QR. I do notice an improvement in front end stiffness with the QR15, but its not night and day enough to make me upgrade my current fork. I should note I weigh 140 if I was taller/heavier or running a 29’er I would most likely upgrade. If I was building from scratch and choosing a fork and front hub I would probably go that way due to the extra security of holding the front wheel (wheel ejections from disc brake forces with standard QR’s are rare, but can potentially cause devastating injury). The QR15 is probably faster to change than a standard QR with lawyer tabs.
There are adaptable hubs, but they are usually heavier and it will take some time to change out.
Kevin
I haven’t used one, but I do think that it’s easy to become too overly focused on stiffness. I have and have had bikes that trend from a 2.75lb SID worldcup (28mm stanchion) to the fox float RLC and have a noodly ultra light CF HT and various FS rigs. Stiffness will affect the ‘feel’ if and only if you are someone who’s very in tune with the handling feedback. But ‘feeling’ the stiffness and having it improve your performance are 2 very different things.
My educated guess is that you are not going to be faster with QR15.
Exactly, stiffer is not always faster/better. I am still running a 4 year old Sid with 28mm stanchions. Would you also want to be getting new front wheels for the QR15 setup?
Need a new (26") wheelset anyway for my HT (only have the frame and brakes right now…)
Will probably go with Stans,
with a Hope Pro II hub which can go from regular QR to QR15
or American Classic if I stick to regular QR (lighter)
I’d like the new wheels to fit on my FS as well, which has regular QR
It would be nice if it could be done on the fly, but not critical.
I.e. going QR15 would cost me some flexibility and add’l$, and I’m not sure what I’m getting back…
I weigh about 175 lbs right now, carrying 10-15lbs of -temporary- excess weight that needs to go :slight_smile:
My hope would be that a stiffer front end would help me come down technical descents faster due to increased control / confidence
My fear is that it’s a losing proposition…
a) I can’t tell the difference and I lost flexibility and $
b) I like the 15QR and will have to spend $ to upgrade my FS
So I’m leaning towards regular QR…
QR15 is nice, but in your case i’d definately stick with the normal dropouts. if you want to add stiffness, go for stiffer steel axle QRs such as shimano XT. but then again, if you ride on superlight wheels, with 2.25" tires at 2 bar you might not notice any difference
I think the heavier duty axle systems were created for durability reasons and not handling reasons.
Consider big cushy tires inflated to 30psi (quite common for best XC performance). You can’t tell the difference between tire flex and shock, axle, rim flex.
When you say ‘technical descents’ I’m not sure if you mean challenging rocky/rooted fast descents (not technical in my book) or the kind of stuff you huck your way down hopping from boulder to boulder (not an XC type of usage).
soft and cushy and flexy will get you just fine down a fast, broken descent.
Technical, as in hard to keep a nice line due to turns or roots/rocks etc. (planning on XC usage only)
But I think I’m with you on the overall flex…
Will be running even lower pressures probably, which is part of the reason for going with Stans in the first place.
So I’ll be sticking with regular QR
It seems like quite a few people think through axles, such as QR15 will be the future for MTB though.
I guess we’ll see…
Thanks for all the input.
Ron.
Follow up question…
How likely is it that I can easily switch out wheelsets anyway, even if both are regular QR?
I’ll be running different disc brakes on each bike
FS: Hayes El Camino (160mm)
HT: Magura Martha SL (160mm)
and different hubs
FS: XT / Mavic717
HT: AC or hope / ZTR355
as long as your rotors are the same diameter, you should be fine, I do it all the time with my wheelsets, different rotors and different brakesets on the bikes, avid juicy 7, formula r1 etc.
the Stans rims are really nice, I just built up 2 new sets of them for my 29er, both have the white arch rims, one set has the DT swiss 190s and one set has american classics. so far have only used the american classics but they are sweet. AS for the qr15, it is pretty badass, ( I dont have it). but not the end all be all. I think a front hub with a higher flange is a good compromise, especially on a 29er.
I am in a similar situation and I straddled the fence by buying the Chris King hubs in a Stans wheelset (through Dave’s Speedream wheels).
The King hubs (and several others including the Hopes I believe, but check that) have the ability to swap out axles and replace
them at a later date for QR15, Maxle, 20MM etc…
So I bought new wheels and kept my old standard QR fork - but I can easily swap the axles for QR15 if I replace the fork next year.
If you are starting from scratch, I’d say it makes sense to go QR15…
As far as brakes go - you mostly want to pay attention the rotor radius. A wheel with 160MM rotors will *for the most part ***be interchangeable
among Hayes, Shimano, Magura, etc… of the same size. Same for 185MM, 205MM…but try it out before you buy/commit.
20mm Maxle Lite is lighter than Fox’s QR15.
The idea of thru axle designes are great for 29ers for the added stiffness due to the larger wheel diameter and if you are doing rough descents with alot of babyhead rocks so it is more a point and shoot descent instead of picking your way through it.
I am getting a 29er soon and will be running a 20mm Maxle Lite set up for my wheels should really help, and added benefit to help stiffen up the front end would be if you could get a 1 1/8 to 1.5 inch tapered head tube as well, Giant did that on their new 29er with the Fox 15QR extremely smart design.
Branden
the only problem with MAXLE is that you aren’t running a fox fork.
