I was lucky enough to get spat in the face on my ride home tonight. To make matters sweeter, the officers that arrested the guy told me to go and get some emergency blood tests as the guy is a known drug user.
I’ll be speaking to my doc tomorrow but was wondering if there are any on the board that could give me the low down on if the police were being over-zealous. I’m up to date with my hep a + b and am wondering if it’s totally necessary.
Go to the hospital and talk to the infectious disease doctor. Did it get in your eyes? Is he AIDS positive? You’re probably fine, but you need your peace of mind. Good luck…
I’m a FF/Medic. I have been to the hospital more times than I can count for exposures like that. The only ones that the docs seemed concerned about were the confirmed disease carriers. Although, I get tested every time anyway for: 1. Peace of mind, 2. So when I do end up with something, I have a test that says I didn’t have it on one date, but do now.
So, the doctors may tell you that there’s very little chance of you contracting anything, and there probably is…but I would get some labs done. FWIW, you will have to go back a few times for HIV tests.
Did it go into your mucous membranes? Only chance of transmission would be if spit went into eyes, nose or mouth… Even with that the actual risk of disease transmission would be extremely small. For example, the risk of Hep C transmission even if he was positive would only be about 1% in an actual needle stick. Best to get checked as per routine because some disease such as Hepatitis C can potentially be cured if its caught early in the labs. Piece of mind is also worth checking.
I’m not concerned about anything in particular. I’ve had plenty of lactate tests but nothing to guage general health due largely to an irrational needle aversion.
I figure I may aswell get some general heath tests run on it if possible to see if anything nutritional needs looked at. What would be the major ones to request? I’m pretty ignorant where blood is concerned.
I’ve raced elite for the last couple of years and am currently putting in 18-20 hours a week base building at the moment if it’s relevant. Thanks for any pointers.
General Nutrition do Electrolyes Panel, Liver Panel, and CBC, Iron studies as mentioned above. If you have a family history a Cholesterol Panel would also be good. Unless there is a specific issue this would cover any general health or nutritional issues. Additional studies could be done if any of these are abnormal…Hope this helps
