Any guys out there have laser hair removal?
not to mention as his/her first post. Well done.
Does this guy lose his man card for shaving? He does legs, arms, chest…
He loses his man card for looking like a deformed freak. The fake tan does not help either.
That, and the raisins he is likely packing.
but he’s in the lava field at kona!!
Many clinics and spas that perform laser hair removal market this treatment for permanent results. This wording can be tricky and before you set out to achieve a hair-free area, you should know what to expect.
Hello lorrimoris and All,
From Wiki:
Excerpts:
Permanent hair removal
For over 130 years, electrology has been in use in the United States. It is approved by the FDA. This technique permanently destroys germ cells responsible for hair growth by way of insertion of a fine probe in the hair follicle and the application of a current adjusted to each hair type and treatment area. Electrology is recognized by the FDA as the only permanent hair removal method.
Permanent hair reduction
Photoepilation
Laser hair removal (lasers and laser diodes): Laser hair removal technology became widespread in the US and many other countries from the 1990s onwards. It has been approved in the United States by the FDA since 1997. With this technology, light is directed at the hair and is absorbed by dark pigment, resulting in the destruction of the hair follicle. This hair removal method sometimes becomes permanent after several sessions. The number of sessions needed depends upon the amount and type of hair being removed. Equipment for performing laser hair removal at home has become available in recent years.Intense pulsed light (high-energy lamps)Diode epilation (high energy LEDs but not laser diodes) Clinical comparisons of effectiveness
A 2006 review article in the journal “Lasers in Medical Science” compared IPL and both alexandrite and diode lasers. The review found no statistical difference in effectiveness, but a higher incidence of side effects with diode laser based treatment.
Hair reduction after 6 months was reported as 68.75% for alexandrite lasers, 71.71% for diode lasers, and 66.96% for IPL. Side effects were reported as 9.5% for alexandrite lasers, 28.9% for diode lasers, and 15.3% for IPL. All side effects were found to be temporary and even pigmentation changes returned to normal within 6 months.
Modalities
Three methods or “modalities” are used in electrology. Galvanic, thermolysis, and blend all have their own merits, and one method is not better than another. The success depends on the skill of the electrologist, the type of hair being removed, the condition of the skin and the pain threshold of the client. All three methods, when properly performed, can be thorough at destroying the hair matrix cells, and leaving follicles incapable of regrowing hair.
Galvanic
This modality is named after Luigi Galvani and uses a person’s body as an electrolytic cell. Galvanic electrolysis was first reported in the medical literature by ophthalmologist Charles Michel in 1875 to remove ingrown eyelashes in patients with trichiasis. A galvanic epilator is essentially a positive ground power supply that delivers 0-3 milliamperes through the body. The follicular probe is the cathode of an electrolytic cell. Sodium hydroxide formed at the cathode by the process of chemical electrolysis kills the hair matrix cells. Modern galvanic epilators automatically adjust the voltage to maintain constant current.
Thermolysis
Another method is known as thermolysis, RF, shortwave or diathermy. Thermolysis was developed in the 1920s and first reported in medical literature by Henri Bordier. A thermolytic epilator is essentially a radio transmitter, usually with an output of about 0-8 watts at a frequency of 13.56 MHz. RF energy emanates from the probe tip to tissue within about a millimeter. Thermolysis works by heating the hair matrix cells to about 48 to 50 °C (118 to 122 °F), causing electrocoagulation.
Blend
Galvanic and thermolysis are often combined in a method known as blend, developed by Arthur Hinkel in 1948, which uses both RF and direct current, combining many of the advantages of galvanic and thermolysis.
My wife bought me a 1 year unlimited laser hair removal for my back, I took the hint… it hurt and did not work. Maybe she will take my hint about some elective surgery for herself… unlikely.
http://lh4.ggpht.com/fisherwy/Rv-7t4pBJqI/AAAAAAAAJRk/9cuX_5gaBdo/Mr.png
Yes absolutely does loose his man card. Probably never had it.
Also his balls are the size of peas from all the roids.
No balls! As fake and plastic as Barbee!
Man hood used to mean- being practical, problem solving, getting stuff done.
Not prancing around like a monstrosity out of some gay porn magazine.
Any fetish - involving a man and a male body (including ones own) is of dubious manliness.
Leg’s only?
If you want Aaron Rodgers’ approval, you’ll get the ass done too.
You realize this thread is from 2008, right?
Apologies. You were still in love with Favre back then.
Brent was in New Jersey.
I have had laser on my back, back of neck, and shoulders. I was worried about the hair just “stopping” on the arm to shoulders, but surprisingly, they can do a pretty good job of blending. To truly end hair forever, it takes up to 9 treatments, 6-8 weeks apart. Also, the hair must be dark in color. If you have light colored hair, blonde… probably a no go for good results. If you are going grey, same thing… not good results.
As far as pain, the first time it kinda was crazy. It felt like a shock (if you ever have been hit with 110 volts in your house)… Repeatedly, a jolt at a time for an hour. Some areas, like love handles, back of neck, spine, hurt more than other areas. Being honest, after more treatments, I am kinda use to it. They have threshold levels on the machine. My first treatment was like a 6, now I have been doing a 10 or 12 and frankly, my memory of the 6 was worse than the 12 today. Partially, it depends on the density of the hair in the area being treated. They use a hand held laser tool, they touch the hand held tool on the skin and it zaps about 1.5" x 1.5" at a time. They have to cover then entire area being treated. A large area, like the back, can easily be 1000 pulses.
I like the results. It is pretty cool to get a hair cut and never have hair grow back under your hair line on the back of your neck. I considered getting my face done so if I don’t shave, it grows in like a perfect beard. Whats the point of hair up on the cheek bones or neck…
Anyway, there you have it.
I never did my legs. I also don’t shave them. I just trim my legs with the smallest guard that comes with the trimmer. I think it is 1/8".
**Do you want to remove unwanted hair from different parts of your body? **
There are different laser hair removal treatments which include Diode laser hair removal treatment and Alexandrian Laser hair removal treatment.
Laser hair removal treatment is the best way to remove hair from any part of your body, and is medically proven to give long term hair reduction.
Laser hair removal gives you long lasting results and requires least maintenance is of better worth compared to other hair removal methods. Get consultation from Dr. Nivedita Dadu offering laser hair removal in Delhi.
Best Laser Hair Removal Clinic in Delhi
Best Laser Hair Removal in Delhi
Laser Hair Removal Treatment in Delhi
Does Dr. Dadu offer services in Arizona? Very interested.
Can I get a home visit in Texas? I’ll pay extra.
your in luck they have a local office
The resurrection of this post clearly merits a Wow. Just. Wow.
Sorry Bro, We are available in India Only. Sorry for inconvenience.
Sorry for inconvenience. But we are available our service in India only. But in future if we get a plan, we will definitely go for Arizona.
