Ok I am the one with the high VO2 max and I am just trying to understand the print out here… Did the test twice on the bike 79.6 and 80.4 and did it on the run today 84.9… But today, the numbers were raising to 70.7, then went down to 66 and back up to 84.9… does that mean anything? how about the RQ? Does that mean anything? I am sorry to be stubborn but I am trying to understand the test and am tired of people telling me “it just can’t be this high” but can’t explain WHY… I want to know why… thanks
You don’t give up do you? Is there any way you can get me that stuff and I will drop it off at Nate’s if you want me to. He may have an answer for you. Let me know…
Why don’t you post the entire result and the protocol by which it was obtained (assuming you can get it)? Without this information people will just be guessing. Even with it they may still be guessing but, at least we will have a chance to answer the question.
I don’t have it on a computer… but i would like someone that really understands this or does the testing… maybe i can fax stuff over or pm…
If you can’t post the data or somehow make it available to everyone then it seems you should be asking your question in private, otherwise no one else will know what the hell everyone is talking about.
One question you might ask the person who did the test is when was the last time his equipment was calibrated? there is a lot more to answering you question than looking at your print out. the protocol and equipment used may be just as important as a source of error.
Frank
Weren’t the first 2 tests done in two independent locations?
Marisol,
Out of curiosity, why don’t you ask the people who conducted the test to explain everything to you? I believe you said that you also have a coach. Did you ask him to decipher the results?
Like Frank said, without knowing procedures, protocols, it is tough to just give an answer.
PM me and I can try to help you as I provide Vo2 testing to my clients, probably on different equipment then you are being tested on. If I cannot help, I can forward the results to some of the Phds who are on my advisory board who may be able to help you.
The tester said it’a accurate. I haven’t faxed the results to my coach but talked to him, he said i might just have the potential but haven’t used it yet… Like i have the “engine” More about the test…
I have 3 seta of tests results, these recent ones were done today. her equipment is new, and she uses new leaf. I have a whole printout with numbers. She gets "normal"results with everyone else… not me… so she thinks that IS what it is… I am doing it AGAIN on the bike wednesday.
Peak vo2=84.9, LTH 172, vo2 at LTH 50.6 %max at lth is 60% test done 12-17-04, on treadmill by Revolution
peak vo2= 80.7, LTH 150, vo2 at LTH 50.5, 5max 63 test done 7-13-04 on the BIKE by Revolution
paek vo2 79.6, LTH 152, vo2 at LTH 43.5 test done on 4-2-04 on my BIKE by coach TROY
Thanks for wanting to help, I would like to know, once and for all.
I may be missing something (I am NOT an expert). But a quick google came up with the following:
http://www.bodyresults.com/e2vo2max.asp says: Highest VO2 Max ever recorded for a man: 94 (Nordic skier), Highest VO2 Max for a women: 77 (Also Nordic skier); *from Cyclist’sTraining Bible by Joe Friel, 1996
http://www.coolrunning.com/major/97/training/hampson.html lists the highest woman at 73
http://www.runnersweb.com/running/vo2_js.html list the highest woman at 74
http://www.lancearmstrong.com/faq.html lists Lance’s VO2 max as 83.8
So…based on my three minutes of research, the test results are questionable. Unless you are running 27-27:30 10K that is? I had this testing done twice and came up with totally different results, so I basically wrote the whole thing off as a waste of time. There are too many other things that go into your performance to get wrapped up in a single number. If these results are accurate, you should be easily winning everything you enter. Sorry, can’t help with the why.
Just $.02 from a non-expert. ![]()
Chris
I know all that which is WHY I am asking… but see most tell me that but they can’t explain why… they just look at me and say no way…
Whoever is doing the testing is doing it wrong. ![]()
It the folks doing these tests are telling you that these numbers are accurate, I’d point them towards all this information to the contrary, and ask THEM to explain it. Or find a new lab.
Chris
I did… went to 2 labs… but also, there numbers are not off on anyone else…
Face it - you are the chosen one. You must accept your destiny and lead us to athletic nirvana.
a high vo2 means nothing. It’s just a predictor of potential. A high Vo2 and a lactate threshold of 30% of that VO2 means your most likely still off the back. A mediocre Vo2 w/ a high lactate threshold means your probably near the front. High and high means most likely off the front. Other factors go into making one a good athlete not just Vo2.
I tried but there is too much junk on google to sort through… Can someone please direct me to any source (preferably internet) that does a good job of talking about VO2max, particularly as it applies to running and cycling - testing protocols, impact if any on training, correlation to performance etc. I have kind of shied away from it just because it seemed to be mainly useful for nothing more than locker room talk - “Yeah,” he said sniffing nochelantly and sticking his chest out, “I’m an 80. What are you?”, or “Dude did you see the size of his VO2max!?!”
OK never mind - if you have enough time there is nothing google can’t answer. see, e.g., http://www.coolrunning.com/major/97/training/hampson.html, http://www.nismat.org/physcor/max_o2.html…
I dunno Marisol - it sounds to me like you are physically blessed with a high VO2 max. How well it can be used BY you to win races, is dependant on a whole lot of other factors.
What makes you so worried about this number? Are you going to quit your job if its accurate?
The saga continues! ![]()
I am not “worried”, I am trying to understand science and understand the “WHY” part… that’s how I operate in general, I like to understand things and usually don’t settle for “just because”. I am stubborn
But seriously, I am just looking for someone to explain this to me, look at the graphs and show why they say it is or not… I have a couples people trying to help right now… thanks for all your input… and I know it “doesn’t mean anything” but it does to me and also says something about a potential…
Marisol,
Do you know they system that each of the administers of the test were using? It appears that all the tests are coming up the same. What is your HR at V02Max and at AT.
The %of AT to V02max is the important number. hat is what you want to train. The closer you ca get your ATHR to your V02Max Hr the better you will perform. if they used the New Leaf system then they can print out the actual test and get it to you.
Josh Gold
www.pushhard.com
