Clip on’s on a road bike? That’s so nuts that it might actually work ![]()
No, really, I’ve had plenty of Tri and TT bikes and depending on the day and course my time splits might be marginal.
I’m going to have to side with Jack on this one. Go with the tri bike. I raced in a sprint on my road bike (Cannondale CAAD 4 R2000 with 700c wheels) two weeks ago - ave speed 18.8 mph in a sprint triathlon (11 miles). This past weekend I used my new tri bike (Felt B2 with 650c wheels) for the first time in an Olympic distance race (24.8 mile bike) and averaged 20.9 mph and I couldn’t get into the big chain for half the race. If I have a shorter race, I’m going to go out a lot harder than a longer race because I know I can hold it. In an Olympic race I keep my HR down for the first half and then go all out the second half.
So you are responding to data, both mathematical, wind tunnel, and actual road experiment, with “there is no way”
ok
well, thats ok, I’m going to need the 2mph on you, because I suck at running
if you are managing a near tri bike position on a road bike, the number is going to shrink down to about 1 minute, instead of 2
That would be ~1 minute from having an aero frame, wheels, and helmet
I’m not sure how much having your hands and elbows outward rather than centered is going to slow you down.
The bigger benefit may be a little better run off the bike especially during the first couple miles.
If you already know the answer, why bother asking ?
I’ve road-tested. Same course, different bikes, one road, one tri, similar conditions. Done it several times, even get geeky about it and time climbs and descents. I don’t record my results and carry them around with me, but several things are very clear to me.
I realize I can’t control my effort level, but it’s still pretty clear to me that the tri bike is faster with roughly the same effort, so why not do a race on the faster bike? Otherwise, why race?
In the perfect world 2 minutes might be possible. But there is no way that someone who can pedal MAX 20 MPH can suddenly pedal 22 MPH on a tri bike for 10 miles. That is a huge leap. Maybe from 20.0 to 20.2 due to aero position I think is what might be realistic.
If I understand correctly, you are putting up this argument from incredulity against the aero numbers posted by others? Good luck.
The numbers posted by others were tests done in a wind tunnel, not in the real world.
Yeah, right. Go ask Jens about that. Or Tom A. Or rmur.
By the way, nearly all of the wind tunnels of which I have heard exist in the real world. Real air, too.
The aeroness has a bigger impact than it does for you on an Ironman.
Why? Because your excerting more power per time unit on a sprint (I hope) and the aero benefits go up as your speed goes up - in a non-linear manner.
Tat is my thinking as well. Also to consider is that for most people, it makes the run easier. In a sprint I would think this is signicant as you are hopefully, running at a faster pace.
For me at least, there is more % advantage using a tri bike in a sprint. I can get low and aggressive and hold a position for 20-30 kms while pedaling full out. I could never hold the same position as comfortable on a long ride where my effort is more survival mode than flat out over a long distance. On long rides I usually had to add a couple of spacers, etc to gain comfort. Once you start doing that to a tri bike, why not just take the road bike with clips?
Holy crap man, let me quote the article I linked to:
“The difference made by aero wheels is about a one to two minutes. When I was preparing this talk and I got to this part, I didn’t believe the model’s prediction. So I recruited a friend and went out to a fairly flat loop and rode at constant power with regular and aero wheels. The results were almost exactly what the model predicts”
Oh, oh…so you STRENUOUSLY object?? “Objection!” “Over-ruled!” “but I strenuously object…” “oh, then I should reconsider.”
You will bike faster, and you will run faster.
All this info. is well and good, but hell, I just feel faster on my P3. Isn’t that enough?
It’s difficult for me to interpret exactly what you are asking. Could be
You seem to be arguing that point because you are disputing the theories of others as to how much faster one is with that stuff, although, as far as I can tell, you aren’t arguing that there is absolutely no benefit to all that stuff.
So I would respond yes I think it is faster so I would use it in a sprint.
So then I move along to you could be asking:
to which I respond, yes, I would use the equipment that I deem fastest regardless of the distance of the race, much like I would swim, bike and run as quickly as I think that I can regardless of the distance of the race.
The gain that you get is in putting your body in a TT/aero position.
I don’t know about the claims of JM, - but what he says does not sound unreasonable.
If you believe the MIT windtunnel tests, they assert that going slower than 20 MPH, one will gain almost nothing by having an aero bike. And, even at time trial speeds, the bike only accounts for 15 to 20% of your overall aero-ness… (is that a word)?
It is your body position that determines your overall aero capabilities. As they stated, getting an aero helmet is a bigger deal than anything about the bike.
Finally, the only time when you shouldn’t use a TT bike is if the course has enough climbing, sharp curvy descents, etc, - to render being in the aero position, or ride stability, difficult. Or, due to the course, - you cannot ride in the aero position.
I don’t think MIT asserts you gain nothing from an aero bike if you are going slower than 20mph
The slower a biker you are the MORE time you save from aerodynamic improvements.
Yes, you save LESS drag, but MORE time.
Math is great, learn it.
Position Drag @30mph Elite WellTrained Trained Recreational Typical 7.3 0:47 0:51 0:50 0:59 Good 6:3 0:53 0:56 1:00 1:02 Excellent 5.3 0:58 1:00 1:05 1:09
Where is the 2 minutes savings? Your own table/report shows a 58 sec to 1 minute savings over 40K? Cut that by at least half for a 10 mile race - 25 seconds for the elite riders.
Ok! You’re right.
