I’ve got a CF frame and a CF seatpost. When I was fitted, they had to use a lot of anti slip paste to get it to stay put, and when I was out of the saddle and rocking the frame, I hit the nose of the saddle and it rotated.
Any suggestions for ways to get the seatpost to not move around?
Cut up a tube and put a layer around the post.
For my brake levers, I tried tightening nearly to failure, roughing with sand paper and even epoxy. Nothing worked till I tried the rubber.
I had the same issue. Carbon compound, scuffing with sand paper, nothing worked. The seat post would rock back and forth and slide down bit by bit. Eventually I bought some tin and cut a small shim and used that to stabalize the seat post. Worked like a charm and I haven’t had any problems since, but it is a pretty fugly kludge.
John, what about a nice Slice or Blue frameset, we havent had any slipping issues with those
If you are set with your seat height bring the bike in and we could try cleaning it up and using some contact cement, that seems to work well on the stubborn slipping seatposts. You could also consider a different seatpost, if its slightly undersized and the seat tube is slightly oversized that can make things slip.
Kevin
Sure, no prob, trade me even up for the Valdora, right?
Yeah, I’ll probably swing by the shop on a ride thursday or something.
