This picture was taken at the local 10 mile TT course for a 26.4 mph average. But I want to go faster.
My gut feeling is that my back is too flat and if I could bring the aero bars back a bit, my back might be more arched and get a better flow off the helmet.
my gut feeling is that you are sitting practically bolt upright with you entire helmet above your backā¦your shoulders almost your entire upper arm high above your hipsā¦
Not a bad startāI canāt think of a reason that a flat back would ever be a bad thing. Iād suggest actually just pushing your chin down would do the job better than mucking around with an arched back, which honestly sounds silly. You probably can go lower in the front, or at least until your legs uncomfortably strike your chest. This requires stretching out forward even more and learning to roll your hips underneath you, but eminately doable. Worth a shot. This is all said with a grain of saltāno one here knows what you look like at full leg extension based off this one image. What I suggest is not comfortable, and it may close up your hip angle too much to be beneficial. Good luck and have fun.
When youāre done with the position fixing, you might want to buy yourself some speedā¦if money is tight and wheels are not an option, shoe covers will help a tad
ā¦and to steal from Jackmotts fameāa disc cover for your rear wheel.
This is a question Iāve asked myself time and again ā would it make sense to use shoe covers on HIM or IM distance rides? If all you do is break even, it means more ārestingā time in transition.
My gut feeling is that your definition of flat is wrong. Not bad, but I donāt know that Iād call you ātoo flat.ā Tuck in your head, or switch up your aero helmet choice.
Ok so it sounds like I should play with getting the front lower and see what happens. Hopefully getting lower will get the head more in line with the torso. Rolling the hips⦠more weight on the taint? If I do this I must get a new saddle.
Currently my knees donāt hit my chest but they do jostle the tummy a bit. Iām not sure if it is enough to justify staying high, but Iāll lower it again and see how the stomach reacts. For a HIM, do people raise their position a bit to allow themselves to eat and digest?
I am calling TOTAL bs on this one, for a number of reasons:
You are not wearing a skinsuit, and your shorts/jerseys arenāt color cooridnated.
Nothing with the words HED or ZIPP ANYWHERE on on the bike.
Not on a P4.
Thereās just no way youāre a ST member, donāt have this stuff AND can put out a respectable TT like that.
Well if you saw my swim times, youād know I spend more time on the bike than is wise. It also helps that this was at about 5000 ft of altitude.
The socks match the jersey.
Iāve ordered a set of Hed 69s and will order a wheelbuilder.com cover.
Well, for those shorter efforts anyway, Iād agree with dropping your front by maybe 1cm.
Otherwise, the big problem is your head. Itās very high. Ever heard of āturtlingā? You might be able to simply turtle and get that helmet tail on your back. If not, you should find another helmet design that would meet your back.
Then the wheels you have on order will give you another step up.
Yeah⦠rolling hips over will shift the weight around a bit. You should probably be thinking about an adamo, although Iāve managed hitherto to use an old azoto and ride on one sit bone, then the nextā¦
As you stretch out forward, youāll notice that your diaphragm will lengthen, sucking in your belly. So your legs wonāt hit your stomach quite so much, more everywhere all at once. Just keep dropping and/or extending the front end until you really notice a lack of power generation or your legs impinge on your stomach/chest too much.
As I said, not exactly comfortable, but itās about being fast, no? I cannot wait to get off the bike after a HIM due to discomfort, yet I do hold position unless itās a really good uphill. Iāve noted that itās important for me to be constantly feeding myself instead of big gulps every once in a while.
