Analyze my form please
Hello ST’ers. I have been lurking for some time, and wanted to get some advice regarding my running form.
http://www.brightroom.com/view_user_event.asp?EVENTID=4283&BIB=734&PWD
These pics are from my last marathon, I came down with ITBS during the race which I think were due to a newer shoe that I tried out with only one long run on.
(Adistar)
Do I look flat footed?
Arms way to low, and you are pulling yourself through the load phase as opposed to pushing. Over time this will lead to IT probs. Your glutes are probably very weak. See a PT who specialized in biomechanics, get yourself videotaped while running and read the following book
http://www.amazon.com/exec/obidos/ASIN/0736037497/qid=1107871359/sr=2-1/ref=pd_ka_b_2_1/102-5254879-0939340
See these posts also
http://forum.slowtwitch.com/gforum.cgi?post=229731;search_string=search_string;guest=2831849#229731
http://forum.slowtwitch.com/gforum.cgi?post=213031;search_string=search_string;guest=2831849#213031
About the arms to low thing;
did you see the chinese ( or was it japanese) girl(s) in the olympics last summer? I can’t remember what distance either, 5 or 10K i think, but there were one or two of them who held their arms almost 180 degrees the whole race just to pick them a little tiny bit for the last lap.
She figured it saved her energy not to wave around like crazy…like for example Gebreselassie.
Agreed, arms too low. Shoot for an approximate arm angle of 90 degrees or slightly less.
Also, your wrists are turned inward which is kicking your elbows out. With your wrists/hands, think of it as if you’re holding an ice cream cone…fingers are loosely closed in and you don’t want to tilt your wrist too far out or in…lest the “ice cream” will fall out of the cone.
You look pretty upright too. A slight forward lean might help a bit, but don’t lean forward too much.
Matt
I did not see that. I really can’t even visualize it.
As to the proper place for the arms, the book I referenced as a contraption you can make that helps “place” the arms in the proper position while running. I used it a number of times. It works.
I think you guys went for this one hook, line and sinker.
I agree with most of the above posters that the arm carriage is much too low. If you bend your elbows more, you shorten the lever (i. e., the effective length of the arm) so that it takes less energy to swing it forward and back. That’s one of the points I’ve worked on in my recent tempo runs, and I think it played a role in my recent marathon success.
Huh?
you could be right . . . did not think of that
Just signs up today? Asks about his running form? Posts pics of a guy basically walking, with arms flapping out to the sides?
Chinese runner. I immediately thought the same thing when I open this thread.
Perhaps I am wrong with my thinking but I believe form is something that will come naturally with improved fitness and running ability. Low arms may indicate exhaustion which would be easily overcome with improved conditioning. Same goes for stride…etc etc
this isnt a troll LOL!
I know it looks like I am walking in these pics, which is really weird to me.
I have lurked for some time, but this place is more technical then letsrun where I just get flamed for even asking a gasp, running question.
I ran the half split in 1:47:00
I basically can manage a 7:30-8:00 min mile.
To hear yourself being described as basically walking and flapping your arms is humbling, but funny as well.
edit, thanks for your replys, even in the face of possible troll bait.
Your last marathon, eh? I admire that you’re doing them. Don’t view this as hostile commentary, but I would recommend that you shed a few pounds. Your arms don’t seem to contribute to your forward motion at all but rather seem to serve a function similar the balance pole used by tightrope walkers. You hardly have any lift in your stride although the shuffle stride is useful to marathon runners. It appears to me that you could find a compromise between lifting and the shuffle. The ITB could stem from many sources. How long have you been running? Your bio indicates more than one marathon. The torque created by the rigid arms has to go somewhere and perhaps this is stressing your legs as you attempt to hold your upper body core in place. This is all based on viewing static photos and not on any kind of dynamic view other than that derived from the images. The suggestion to get a PT is a sound idea.There might be a master’s running program in your area so you can hear ideas/criticism first hand rather than hear it from clowns online who are isolated from the situation, like me.
I just reread this. All is speculation so I send it in that spirit. Join a club and get a trainer are the only pieces of information that can even be considered as immutable.
I didn’t see a bio–how do I view this?
I implied it. If someone only runs one, the reference is usually to “my first marathon,” and, since last and first are one and the same, last is refered to as first. If more than one, the reference to the most recent one is “my last marathon.” Who knows? Maybe he breaks the mold. Maybe there is no mold and I created it on my own. But, in light of your comment, maybe I should have asked him how many he has run instead of going out on a limb. Mea maxima culpa. Anyway, thanks for pointing out my flawed logic.
(Gee, tough crowd.)
My goodness. Suspicious much?
Even if it is/was a troll (which I doubt) this would be a pretty inept way of trolling.
You went out at a 3:35 pace and then died. What happend? Too often folks push the front end and pay for it later…whether it be injury, pace or nutrition. I could be wrong, but your splits are literally what happens to nearly all 4:00 pursuers.
Each person has their own “natural” running style…although it can be tweaked with some focused work.
Check out the following…
http://www.byrn.org/gtips/runtech.htm
http://www.byrn.org/gtips/runmech.htm
no offense taken on the weight comment.
i am 5 '11 176LBS
most people I know say I am too skinny( non runners), so maybe they lie!
This was my first run at the marathon. I had run the Army 10 Miler, Birmingham Half Thon, a few 5k’s and about 4 10k’s previously.
I trained pretty regularly and did the prescribed 3 20 mile long runs. I did brick workouts when I felt injured to simulate the exercise time, 10k plus 20 plus mile rides… I suffered through bouts of nagging injuries, boredom, loss of libido… etc…never in any of my runs did I encounter anything like the pain I had in my left knee (ITBS). This was something I simply couldnt run through, and had to walk about 1/4 of the remaining 9 miles.
Aerobically I felt fine, but once the reality of a sub 4 marathon hit me I was able to re-prioritize my goals, move on and just finish, which was difficult because I figured I was damaging my body at that point, not to mention the dissapointment of seeing the training blow away.
Today is the first time anyone has told me to lose weight. That, as well as my form being likened to a walking flapping fat ass has energized me to train hard.
No, I really thought you meant there was a bio, I wasn’t pointing flawed logic.
Is ITBS a self-diagnosis, or is there a physician involved somewhere in the medical evaluation. Knee pain can be lots of things.
