Have any of you ever tried the deck tape that’s used on skateboards?
That stuff comes in different coarseness, stays on no matter what’s done to the board, and it seems to me like it might make for good coverage on the ends of bars like the Vision and other similar aero bars where it’s difficult to wrap tape around the brake-ends.
I think that the ‘grip tape’ would be a little harsh on the hands. I know that you are not gripping very hard, but it is essentially sand paper and I have to believe that it would wear on you after 112miles.
I use Pete Sampris (sp) Tennis Tape. It comes in charcoal grey and is very thin. I do the extensions and the pursuits with one package. Pricey stuff though, it goes for about $3.95
Cheap. Grips well. Just use a heat gun and it forms to the bars. You can even put gel under it if you would like. It is more than thick enough to avoid tearing. And…it looks great.
It is made for fishing poles and can handle moisture.
If I remember correctly, you simply buy by the foot. Very inexpensive. You can cut it with a sharp pair of scissors to the exact length that you need. It comes in 3-4 diameters. Works great for me.
Is that stuff any different from the heat shrink tuning they use for electrical applications? That stuff seems pretty touch, but I’m thinking it would be slippery when wet. Given its designed for fishing I’d hope that this one is kind of “tacky”… What does it feel like when wet? Dry?
Sorry I did not answer the whole question. It does not shine like the tool dip - more of a matte finish - but it is very much like a combo of tool dip and shrink wrap. This however is much more durable than tool dip.
I thought the same thing when I first found it - that it was large electrical conduit housing. But it is not. That type of thing is a hard plastic. This stuff is rubber. Much more flexible in your hands and it feels like rubber. It is made for fishing poles which get wet by design.
I have sanded the exterior to give it more texture and thus more grip. Works great for me on Oval 900’s (although getting it over the brake lever housing was tough) and Hed aerobars. Both on the aero extensions and the basebar portion.
Hmm, interesting about the brake levers on the Oval bars - I’ve got the same bars and it didn’t even hit me, but yep, that would be a problem. Do you recall what size you got? Did you take the brake lever off first and get it on that way or were you able to get it past the there with the lever on the bars?
I purchased a bit of everything. But I think it was an 1 1/4" for the Ovals. But I am not 100% sure. And yes - the levers have to come off. Use some soap and water to slide it over the brake portion. I actually but gel under it so that may alter sizing issues as well.
