Am I damaging my alu frame by bunny-hopping?
I’m on a 9 yr old giant tcr aluminum frame. I’m wondering if I’m weakening welds or other things by bunny-hopping pot holes or other road debris. It isn’t often, maybe once every other ride - sometimes less. There are times shadows hide things until the last second or if I get forced too far right by traffic and I jump them so I don’t kill my rims or risk a fall. Is it ok or cease and decist.
thanks
Barry
I’ve never heard a problem with this. I bunny hop stuff all the time. Speed bumps are the most common, big ones!! Though my bike is carbon, I always did this with past alum frames, too.
LOL, I just busted out laughing at the title. Sorry, didn’t read the substance.
I’m pretty big and while I am no bunny hop expert, it doesn’t feel like its really that stressful on the bike since I seem to have some control over how hard the landing is. I know my teeth hurt when I hit potholes but they don’t coming down from my epic 1/2 inch bunny hops.
You have to do a cost/benefit analysis. I did a sweet bunny hop this weekend over a pothole that was about a foot wide and 6 inches deep. I think I got 3/4 inch of air this time. I was pinned in by cars on one side and high curb on the other so it was either job the hole or die. Whatever stress I put on my frame was way better for both the frame and me than hitting that hole :wink:
The short answer is no. The long answer is noooooooooooooo.
Aluminum has finite fatigue life at all strain levels. Every pedal stroke, bump, pothole,etc. takes a little life out of the frame. That’s not as bad as it sounds. From a design standpoint what that means is that Al frames are designed based on worst case scenarios (ex. what is a 300lb. guy rode this bike 50miles a day over cobblestones for five years). The result is that frames can easily take the stresses of bunny hops and these will not wear out the frame appreciably faster.
I have a Cannondale from '91 that I regularly bunny hop over bridge expansion gaps on my rides…no worries.
LOL, I just read:
as:
I’m a 9 yr old on a giant tcr aluminum frame.
If that were the case, bunny hopping would be a normal expectation of riding. :slight_smile:
If you’re bunny hopping to avoid a shock from a bump or hole, I’ve gotta think you’re doing less damage than the greater shock of hitting the bump or hole would have caused.
I doubt you’re really “bunny hopping”… more unweighting the bike. In which case you’re fine.
Unless you give it a power stroke to bring the front wheel up then match with the rear… and in that case WTF?
No, though its hell on the bunny.
