ALuminum tri bike $550, includes shipping and disc
Here is what the spec sheet looks like
Aluminum custom frame by Mark Zeh 54cm top tube, 77 degree seat tube angle, 13.5cm head tube (built around 1999)
Profile BRC fork (new as of 2005)
Profile -25 degree stem (new as of 2005)
Syntace Base bar (brand NEW)
S bend aero bars with profile pads (new as of 2005)
Shimano 600 shifters
Nashbar chain, brake levers and calipers(new as of 2005)
Shimano 600 front and rear derailleur
8 speed shimano cassette (brand new)
FSA Gossamer crank and matching BB (new as of 2004)
Alien Aluminum seatpost
Selle Italia seat with QR cover (new as of 2005)
Rear wheel - Shimano 600 with open pro
Front wheel - trek matrix hub and rim
included in price above is Araya Disc that uses a freewheel. Includes a 8 speed Sachs freewheel and a glued on tubular tire. it uses nomex construction but is a little weighty
The bike is in fairly good shape. There are some paint problems (probably 5 scratches or so, about 1/8 to a 1/2 inch across and an inch long) but thats because there was never a clear coar applied. I am the second owner it has always ben stored inside. I put it together fairly cheap to get me through this past year and hopefully someone else can use it as a good starter bike. I can send a picture to those interested. As you can see basically everything is new within the last couple of years except the frame, shifters and derailleurs. Probably fits like most companies 56
550 gets the disc, bike and includes shipping and packing by my local bike store who charges $65.
I don’t have a current picture of the bike but this gives you a really good idea of what it is like. There are some changes I made however: The front Spinergy wheel is not included (only an older 32 spoke training wheel)
The seatpost and saddle are different than the picture, I now have a blue aluminum Alien seatpost with Selle italia saddle and black cover. The Vision Tech basebar that is in the picture is not included, in its place I put a new Sytace basebar http://tinypic.com/f08apl.jpg As you can see its got a tall head tube, so if you normally have to run a bunch of spacers, this may be good for you.
I am extremely interested in your bike but I am not sure if the top tube will be long enough. these are my numbers:
measurements in cm:
Height: 186.69
Inseam: 85.09
Torso:152.4
What do you think? i will post on the main forum and ask for opinions.
Dan
www.aiatriathlon.com
also, could you send me the other dimensions of the frame?
Thanks again,
Dan
Bump?
What does it mean when someone writes “Bump?”
Would you consider parting out anything?
I’m interested in the seatpost for sure.
