Ender - i like the one2 more because it’s lighter and more flexible. there’s obviously a little more cushioning in the torins, but i feel there’s enough in the one2 for my needs.
I have run in both the Bondi B and the Altra Olympus. My current favourite is the Olympus and I plan on running this winter exclusively in them. I find the Bondi B too squishy in the forefoot. The squishiness of the Bondi B irritated the metatarsaligia that developed from running and racing in the Pearl Izumi Tri N0 and N1. The Bondi B also did not agree with my toes, I was constantly getting blisters and black toe. I think this was from the hard toe cap.
The Altra’s are not the coolest looking shoe around (due to the super wide toe box), but they feel amazing when running. I always ran in a 4mm drop and I easily transitioned into the zero drop Olympus. As soon as I started running in the Olympus my metatarsaligia was gone. The Olympus are listed as a trail shoe but they should really be considered ‘light’ trail only and road suitable. The tread is good in the dry off road but not up to the task of wet roots slippery trails. When you first walk around the store in the Olympus they feel very forward slanted, but it easily translates into a smooth forefoot strike when running.It would be great if the Olympus were a few ounces lighter, but it is not an issue in the off season. I figure I will easily get 300miles on the Olympus vs the Bondi felt very broken down by that point.
I too have flipper feet (narrow heels and wide fronts). I have run in the Stinson, the Bondi3, and the Altra Olympus. The Altra is a great shoe for wide feet types. Took a little while to get used to the zero drop design, but now I would never go back. FYI, the new Bondi4 is supposed to have a wide feet version as well (January 2015?). Hope this helps.
GG
Hoka is coming out with a shoe called the “Constant” in 2015. I’m also a wide-forefooted guy and the Bondi 3 is the only Hoka I can wear, and it’s “just” wide enough in the toe box for me. I’ve tried the Altra Paradigm (too firm for me) and the Olympus (metal eyelet gave me a blister on the top of my foot). From Runblogger’s site:
“Description via HOKA: “The new Constant road shoe offers the most stable ride and generous fit in the HOKA lineup. The combination of cushioning EVA and RMAT® high-rebound material delivers guided stability and increased durability, while an over-sized active foot frame provides support. A mono-wrap tongue coupled with asymmetrical lacing supports the foot through the arch while reducing pressure across the top of the foot. The Constant will be available at specialty running stores for a suggested retail price of $160.””
Sounds like the “Constant” is a stability shoe whereas the Altra’s are more neutral. My problem with Hoka’s (Bondi 3 included) isn’t the width of the heel and midfoot, it’s with the toe box which is tiny. The problem with switching to Altra is that you can never go back…I now have a pair of almost new Clifton’s and Bondi3s in 9.5 and 10s that will never been worn again. I haven’t tried the Altra Olympus/Paradigm yet but will give them a try. If I were Hoka I’d copy the toe box of Altra and you’d have an amazing shoe.
GG
Can anyone compare the midsole firmness of the Hoka Conquest & the Altra Paradigm?
The Constant will be a neutral platform that provides support through the active foot frame (the sidewall wrap). Basically, the Constant, like many of our shoes, should be supportive if you need it, neutral if you don’t. The Constant should be even more supportive, if necessary, than our previous models, and should also have a roomier fit.
Sounds like the “Constant” is a stability shoe whereas the Altra’s are more neutral…
…FYI, the new Bondi4 is supposed to have a wide feet version as well (January 2015?). Hope this helps.
GG
Hoka is coming out with a shoe called the “Constant” in 2015.From Runblogger’s site:
I have never run in the conquest, but I found the paradigm stiffer than any of the Hokas, except for that Rapa nui. I found those two to be more comparable.
If you currently run in kinvaras and want more padding, its bigger (and more cushioned) brother - Cortana, has been great for me
This!
This!
x3.
I’ve had the Hoka Bondi 2s, Stinson Tarmac, and Mafate, and never found a good toe box fit. I did a 3.5 day adventure race in the Stinsons (last year) and Mafates (this year), and wound up with pretty good blisters from the narrow toe box both times. Especially the Mafates.
After that, I bought a pair of Altra’s The One (or whatever) on sale. I like the wide toe box, but it may be too wide. Sometimes it feels like you could add a couple of extra toes in there and be fine. But the squish is nowhere near the Hokas. It is much firmer.
The Stinsons were the best ‘wide toe-box’ fit I found for Hokas, and my next pair will likely be the trail Stinsons (since I run most on trails…duh).
I do like the motion control aspect of the Altras. I assume Hoka will get around to making some form of motion control shoe in the future, based on market demand. I don’t completely buy their "it’s only the squish that matters’ argument on that issue.
I have 10+ runs / 50 miles in Altra Olympus and for me the shoe is just … Weird.
Cush, yes. Traction is great. But I’m not sold.
… I have been in standard shoes, most Saucony (Ride-Guide-Triumph & Mirage) for 5 years, with a pair each of Asics 2000, Speedstar & Brooks Ghost thrown in.
Everything hurts more than it used to (I’ll be 45 soon) so I am looking for more cushion. Not sure what’s next. The new Triumph has 20% more cush so I may just try that before I go to something “weirder” like Hokas …
This!
x3.
x4!!!
Totally agree. The reasons I like the new Bondi 3 is for the toe box. Not too sure ‘why’ the toe box on the rest are so friggin narrow. Stinson and Huaka…time to allow for some foot splay. It is obviously their market is for ultra distance runners…why may the shoe so narrow?
Do you get crazy heel slipping?
My Olympuses came today, and the toe fits the way it is supposed to, but my heel slips a ton…I can actually slip the shoe right off my foot.
Mine felt a little big at first also. I make sure I am running in slightly grippier socks and I have the laces fairly tight. I vary between a 10.5 and 11 in most shoes. I am in a size 11 in the Olympus. Have you tried them on a treadmill? if they are truly too big you hopefully you can try to size down half a size.
I usually run in an 8 (yes, small feet…like hooves), but I ordered an 8.5 because I heard they ran small.
I ordered an 8. I’ll try them both on the mill before I wear them outside.
This!
x3.
x4
When I picked up a pair of Cliftons I thought it was a game changer. A week later I had extensor tendonitis in my right foot that caused me to layoff running for a month and half and miss a race ![]()
This!
x3.
x4
x5! wait can you times yourself?
The Bondi B3 is perfect for me all the way around…except I blow through the outsole in like 50 miles.
I will compare the Stinson Tarmac to the Altra Olympus to see which one I like better.
This!
x3.
x4
X6!
Love my Hokas but the toe box is lacking. Trying to find a place in the ATL that actually has the Altra Paradigm to take for a spin.
