Alternatives to the Total Immersion Cult?
Thanks for all the replies everyone, Slowman hosts a kickin’ forum.
I’m checking some of the articles referenced by you guys and googling some names that came up.
Glad to know that I’m not alone in thinking that TI is not the perfect Solution ™ for everyone. For a poor-kicking 30-something Tri guy who can fake an open water swim but is stiff/unbalanced in the water, I think what I need to do is keep up with my 1-1 coaching (non-TI), keep trying to reduce drag in my 3x+ weekly swim sessions, maybe get my ankles surgically de-stiffened, and most importantly, keep checking the SlowTwitch forum everyday!!
The secret to swimming fast is this:
Your hand DOES NOT move - your body does. (Watch a realy good swimmer. Mark where the hand enters and then where it exits the water. It will be within inches of where it went in).
Everything else (technique, , stroke shape, the recovery, training both in and out of the pool - all of it) is intended to make this union of hand to water solid as a cleated foot on a track, to allow it to remain fixed for as long in the stroke as possible and to then to take maximum advantage of this traction by limiting drag and maximizing the force that can be applied.
Go forth and swim fast.
FQS has been around for years. popov used it in atlanta olympics, thorpe does it etc. it’s almost swimming catch up drill at normal speeds. yes it’s faster than having your arms one extended in front one extended in back.
I keep reading that. I have yet to have that feel for the water.
Dave Scott says you should imagine your arm grabbing into sand, deeply, and you pull yourself up to where your hand is. He says, pretend that if you just move your hand quickly across the sand, you will go nowhere. This is in the same vein as, reaching for a rung of a ladder and pulling yourself.
I just can’t get that feel without making my shoulder and triceps hurt. I think a lot of it has to do with getting an aggressive catch. I was reading the other day, where to simulate an aggressive catch you extend your hand parallel to a table and turn your elbow in, touching your fingers to the side of the table. Your forearm is turned toward your face, elbow in front, not dropped. If the shoulder and hand are in this position, its coming forward in front of the elbow, through the water. I guess the idea here is, if you take that contorted position, you have your back forearm, and hand and arm way out front, like a huge cup, you can hold onto the water and pull yourself up, so to speak.
But I can only do that for one lap, because its a shoulder killer for me, at least.
IMO, Front Quadrant isn’t a goal or some sort of specific style. It’s a natural result/effect for most people because the recovery arm is able to move at a faster rate than the in-water pulling arm. Somewhere around 80-90% of swimmers, I’d guess will end up swimming mostly front quadrant left to their own devices.
There are a handful of very fast kayak (arms opposite each other at all times) style swimmers, but I suspect that style of swimming is harder on the shoulders.
Guy with a gun…ugly scene…kittens threatened…tough choices indeed…
-bobo
booth walk up to a table and position your upper body flat like a table. rotate to your right side and extend your arm across the table. Make it a small table so that you can drop your hand down leaving your upper arm on the table.
there is your high elbow position, make sure your palm is facing your hips that enables you to get a good pull
or maybe another way to look at it is that the extension/reach phase is slightly longer such that the stroke does become sort of a “fast catch-up”? almost akin to what TI says i think but maybe TI makes the reach too long so that one would almost come to a complete stop before one starts to pull again with the other arm. i’ve seen people who’ve been to TI who really have a dead spot in their stroke because they’re gliding for two days!
it seems that distance swimmers like hackett and thorpe use FQS while sprinters like Popov and Klim use a more rotary/cyclic motion. probably a natural result of the disparate distances they race? this site has a good explanation: http://www.svl.ch/index.html
Kim
If it hurts like you’re lifting weights and getting muscle failure that’s good. That’s what swimming is supposed to feel like if you want to improve your stroke. Keep doing it as long as you can stand then try to go longer tomorrow. The key is to maintain good form as long as you can. It’s those last few repeats that hurt like hell that are going to lead to improvement.
On the other hand, if it feels like someone is jamming an ice pick in your shoulder, that’s different, particularly if it only happens at certain points in the stroke. You need to have someone look at your stroke. You may have an injury and your form may be causing it.
over the years I’ve written up a couple thoughts on swimming, nothing meant to be comprehensive but might give you some things to think about.
stroke form (this is a word doc)
technique, intervals, and site specifics
interval ideas
I would stay away from straight arm swimming, the recovery doesn’t matter so much for speed but does for shoulder problems. Go with high elbows.
Not for non-German speakers it doesnt!
Yep I tried the TI and it was crap for me. Got things turned around so I thought. Then met a long time swimmer (collegiate champion) and he showed me a few things which corrected the previous problems and helped me speed up again, stay more relaxed, and overall improvement. He isn’t a coach at all but received coaching for manymany years and is able to teach very well.
few points on the straight arm cult for Longspur
the straight arm swim drill is swimming with straight arms on the recovery and the pull phase of the stroke aka windmill style:
  • this feels v weird when you first try it, but after 2-3 workouts it begins to feel great
  • keep the stroke nice and slow + easy
  • use the momentum of the straight arm recovery to generate a rhythm in the stroke
  • as soon as the recovery arm enters the water PULL!!! this will help unlearn the TI glide phase
  • you should have continuous propulsion throughout the stroke - no glide phase
  • try practising without breathing for a few strokes to get used to it
  • keep your body straight and flat in the water
  • remember keep both arms straight in the drill
Andy
(total convert to the straight arm recovery club)
That sounds like it would be really rough on the rotator cuff.
Perhaps I didn’t look long enough, but the major point that people are missing is flexibility. I am relatively familiar with TI’s drills and ideals, but if you can’t get your body in that position comfortably, then you’ve lost.
Now i’m just as fond of becoming frustrated and defaming something on a thread as the next jerk, but TI’s ideas are exceptionally sound. I don’t work for them, I just swim a lot. I think anything mass marketed looses some effectiveness, however.
Am I a good swimmer because I am very flexible, or am I flexible as a result of swimming for 15 years? I seem to believe the latter.
You are flexible because you have the flexibility genes. Stretching helps SOME, but mostly it is genetics. You are a good swimmer because you have the body for it and the desire to maximize your technique and conditioning. You notice that all of the best freestylers have almost the same bodies.
yes it does. it sounds like a way to get away from the ‘s’ curve pull technique. i was under the impression that the ‘s’ curve pull had less to do with efficiency and more to do with injury prevention/most people don’t have the shoulder strength to maintain a straight arm throughout the pull. i have had reasonably healthy shoulders since picking up tri’s and swimming regularly. no way would i go to the straight arm technique as it sounds tailor made for shoulder injury…
you need to have frames. on the left side click where it says “Tips in English”.
Kim
Thanks doc. I see it now.
Below is an article from the http://buehlerbluemarlins.net/ website which I found thanks to some earlier posts. Interesting stuff . . .
Dear Editor
Several months ago in an article I wrote for Swimming World (“The New Australian Crawl,” Jan. 1999), I mentioned that the common expression “swim like a fish” was a rather silly concept. I stated my reasons for that opinion and never gave a thought to the likelihood that I might have offended anyone.
However, I received five very scathing faxers from people in the “Total Immersion” Incorporated Swim Clinic business, who apparently thought that this comment was a direct insult to them and the business, in which they use the phrases “swim like a fish” and “fishlike swimming.”
The truth of the matter is that Mr. Laughlin is not the first one to observe fish swimming and wonder how the inexplicable grace and speed of fish might somehow be learned or transferred to human propulsion in the water. My coach, Dr. James Counsilman, had several aquariums in his house, and we spent a great deal of time in the 1940s and 1950s discussing fishlike movements, especially their ability to accelerate from a dead stop to full speed in virtually the blink of an eye, as well as the phenomenal speed that sea creatures can generate in open water.
I have spent time over several decades, as most swim coaches probably have, observing the propulsive movements of fish. My opinion is that one will learn more about fast swimming in a single session of observing the races of champions such as Inge De Bruijn, Ian Thorpe, Mike Barrowman, Pieter van den Hoogenband, Lenny Krayzelburg, Janet Evans, Lars Frolander, Yana Klochkova, Michael Klim, Kieren Perkins and all the others too numerous to name, than in a lifetime of observing fish.
One item that is totally missing from the TI formula for success is fast training. One thing I can tell you for certain is that anyone who tries to convince you that a few adjustments in balance and position in the water will immediately turn you into a champ is a charlatan. Although these factors are very important, one must train progressively faster and with unrelenting dedication, or be born with awesome natural talent, to become great in this sport.
There are many different roads to success in swimming that it is extremely presumptuous to claim that one, alone, has the magic key to success. Both in terms of training programs and in the so-called “ideal form,” there are no such things.
We all try to contribute a little more knowledge to this sport that we love. Anyone who tries to take the arrogant pose that he knows it all, that he has all the answers, is pulling a big con game.
We do not swim like fishes. We do not swim on our sides. One only has to look carefully at the greatest freestylers and backstrokers at the 2000 Olympic Games to see that the upper torso and shoulders stay relatively flat and stable in relationship to the surface of the water. The arms are extended and the shoulders are shifted forward (not downward). The torque or rotation in these strokes occurs in the lower torso, hips and legs.
I do not know of a single species of fish that swims in that manner. One only has to look at Inge De Bruijn and observe the fantastically efficient stroke she has developed with her super coaches, Paul Bergen and Jacco Verhaeren. De Bruijn’s 24.13 in the 50 meter freestyle (swum in the semifinal heats) may have been the single greatest breakthrough in the entire Olympic Games of 2000. She swam that race with a straight arm recovery and almost flat upper body, much as Janet Evans did during her heyday.
To create torque in a long axis stroke (freestyle and backstroke), one must have a semi-fixed point from which to work. The rotation of the lower extremities of the torso, hips and legs against the relatively stable shoulder girdle and upper torso allows one to create power, or torque, in the stroke.
If the entire body rotates along the central axis , little or no torque–or power-- occurs, and a great deal of the strength and force of the long axis strokes is dissipated. Rotation and the comcomitant torque generated in all power movements in sport occur against a fixed or semi-fixed fulcrum.
That is why golfers and baseball players use spikes to completely stabilize their feet so that great momentum can be generated in the swing. If their feet slip during the swing, it greatly diminishes their ability to hit the ball with any real power.
A similar principle occurs in swimming. However, our semi-fixed body part for the generation of power, or torque, in the stroke is the stable shoulder girdle. If one drops the shoulder and rolls to swim on his side, the power is lost.
The contemporary world-class freestylers and backstrokers, of course, elevate the shoulders on the recovery phase of the stroke, which gives the illusion of rolling. However, when viewed from underwater or above water from the front, during the propulsive phase of the stroke, there is very little change in the depth of the shoulders. The shoulders remain high throughout the pull. Great freestylers and backstrokers swim with very little central axis rotation within the upper body during the propulsive phase of the stroke.
Also, a much narrower frontal profile can be created by shifting the shoulder forward. Great swimmers obviously have many differences in their strokes. However, they do not swim on their sides in what has been described as fishlike swimming.
As a final point, I am happy for everyone at TI for the business success you have enjoyed. With the organizational skill you have generated, you are in a position to continue to make an impact on our sport. However, make room for other people’s ideas and observations. You will be stronger for it.
You think humans swim like fish? There are a lot of people who do not. What’s the big deal? I suggest you spend more time watching swimmers underwater and less time watching fish.
Ron Johnson
Head Coach
Sun Devils Masters
Dear Editor
Your recent article by Terry Lauglin, as well as books, videos and clinics, have been flooding the Masters swimming and triathlon communities, promising to teach the secret to successful, fast swimming. These articles sound impressive, as they encourage us as swimmers to stop trying so hard and start feeling–like the theme of a John Gray workshop. But, as coaches, we are informed that we have been teaching and training swimmers incorrectly. We are told that to swim fast, our swimmes must learn to swim on their side like a fish, and must have and maintain a body position like a racing yacht.
Although some of these concepts have some merit and help beginner swimmers learn to relax in the water, they are not based on biomechanics, principles of propulsion or analyses of world-class swimmers. Since we are not built like fish and do not move through the water like a solid object, such as a racing hull, it is foolish to base stroke instruction and an entire training philosophy around these principles.
It has been stated by the guru of “fishlike” swimming, “The most hydrodynamically perfect position that your body can be in is balanced, lying on your side, one arm extended for length–not so very different from the way fish do it.”
This statement drives me nuts! Fish do not swim on their side. If we take a look at a fish, we notice a large fin sticking up toward the surface of the water. This fin is called the dorsal fin. Dorsal means “back” or “upper surface”.
The dorsal fin is on the fish’s back, which means its back is up, and its front is down toward the bottom of its pond. The fish, it seems, swims on its stomach–not on its side. If you happen to see a fish swimming on its side, you know that fish is dead in the water, the same way you’ll be if you spend too much time trying to swim on your side.
Have you ever seen an article in Runner’s World, “Run Like a Cheetah…on all Fours”? Can you imagine the breakthrough this type of discovery would mean to the running world? We can learn a great deal from the observation of animals in their natural environments, but we should never forget we are not those animals.
Bob Patten
Head Coach
Dallas Area Masters (DAM)
