#1 and #2 are running so they aren’t substitutes for running.
Let’s not debate semantics. They substitutes for running on pavement. Ones that do less damage. As the OP is trying to avoid injury, they might be enough. They are certainly better than any other substitute. It does not sound like the OP is injured and cannot run at ALL, just that he needs less running. Any of the substitutes I listed is a better supplement to running than more biking or swimming
Nothing else is a good substitute for running, so that’s why cycling/swimming will win in my book.
Aqua jogging is an excellent substitute for running. It doesn’t give you the impact and the eccentric contractions that running will but it does simulate the motion quite well. Walking arguably simulates the motion better, it certainly comes closer to working the muscles in the same way. It gives you a little of the impact as well. Mostly it lacks is the anaerobic component.
Additional swimming and running will improve your time to T2 so it’s a no-brainer and when triathletes do any of those other silly alternatives when injured they are making a mistake (as it pertains to maintaining or improving their triathlon fitness).
Additional swimming and running might improve your time to T2 if you are not doing enough of them but the lack of running or anything like it will kill your time afterwards. It’s 3 disciplines, not 2.
I’ve personally witnessed D-1 runners come out of the water after a few months of aqua-jogging and set PRs within a few weeks. More than once. There is nothing silly about it
Joe, you might be right about the OP’s situation. I think we would both agree that if he can run in a modified way that’s best.
Aquajogging is not a very good substitute for running IMO (qualification…not better than most other forms of cardio). You are not fighting gravity in the water so the muscles are not worked in the same way whatsoever. Nor are they worked in the same direction or in the same ratios.
When I was a single sport runner I did some and it was fine. As a triathlete I can’t imagine not picking up the volume in another discipline.
Think about what you said for a minute when you said that additional swimming running MIGHT improve your time to T2 if you aren’t already doing enough…
What’s optimum volume for a cyclist? 200-300+ miles per week? For a swimmer? 30-50K per week? What triathlete is doing that much? None! NO TRIATHLETE is getting so much cycling that if he stopped running he wouldn’t want more cycling.
As for your anecdote of a Div 1 runner getting PRs after aquatraining…I’ll tell you about my identical experience with cycling. I spent my sophomore year of cross country injured and did nothing but 1 hour per day on my wind trainer. I was pushing so stinking hard I was able to hold my HR over 180 from 15-60 minutes in the workouts.
I only ran on Saturdays in the races and began PRing.
Since cycling can be just as good for the cardio system as aquajogging what triathlete wouldn’t choose that?
