Is Tallahassee the closest airport to Panama City for IM?
Hi, you can fly into Panama City/Bay County Airport on Northwest Airlines, Delta and US Airways.
The airport code is PFN on orbitz.com.
Good luck!
Mark
Ft Walton Beach is a decent sized airport, closer than Tallahassee, I think Pensacola is probably closer as well, if you can’t fly in to PC easy.
C
Panama City and Destin are both pretty expensive. Your best bet is Tallahassee (much closer then Pcola). When I lived in Panama City we always flew in and out of Tally.
Ft Walton Beach is only about 55 miles from PCB while Tallahassee has got to be more than double that. If you can’t fly in/out of PCB, Ft Walton is definitely your best bet.
I’ve never found Ft. Walton Beach (use airport code VPS -if you search by city name, you can come up with some weird results) to be terribly expensive to get in or out of compared to other area airports. Last couple of times I’ve checked, it’s run about $5-10 more round trip than going out of Pensacola, which has some downward price pressure because of AirTran.
If you can get a reasonable price on another carrier, avoid Delta’s commuter airline ASA- worst larger airline in the US according to a major national customer satisfaction survey.
PFN is about 10 minutes from the downbeach part of Panama City Beach
Ft. Walton is about 50 minutes away
Dothan, AL and Talahasee is about 1:15-1:30 away, both serviced by Continental
Pensacola is about 2 hours away, and that’s if you’re hauling ass. Almost missed my returning flight from IMFL 03.
Best bet is to book fairly early and get a reasonable fare into Panama City. Any one of those flight options will at least require one connection, unless you are flying out of the airline’s hub for that region.
One additional strike against Pensacola–the I-10 bridge west of Pensacola that was damaged (er, destroyed) by Hurricane Ivan is open for two lanes of traffic only and will likely be that way for years. This could cause you major delays in your travels.
