Aeroframes and stalling
What does it mean when an aero frame stalls? I know what happens when a planes stalls and see not connection.
When your bike stalls, you fall over, unless you put a foot down…
It is the same thing as with a plane.
Take your plane wing, rotate 90deg. It is now up and down like your Cervelo downtube.
Crosswind is now the equivalent of an updraft or downdraft, yaw angle = angle of attack.
If the yaw angle becomes too steep, the aerotube stalls. Same as like a plane.
If a plane stalls it means the flow around the wings is stalled, decreasing lift dramatically and increasing drag, which can cause the plane to go down.
The same thing that happens to the wing in a plane can happen to an aero tube in a bike. Lift will go down and drag will go up.
Have you seen any studies that discuss stalling phenomena on aero bikes or wheels?
Read Gerard’s comments in the “Aero Frames & Wind Angles” thread & JoshatZipp’s comments in the “Aero Wheels & Wind Angles” thread. At 30+ deg, the disc, and I imagine deep wheels sooner, start to stall. Gerard said that Cervelo’s main goal in the wind tunnel (and for frame design as a result of tunnel testing) was delaying stall.
Much to do about nothing, at speeds under 55 mph drag is small on any shape. The tear drop shape is best compared to a round tube. The airflow around a short cord airfoil would need a plus 45 degree air flow/angle of attack to stall or have a steep increase in drag. But since the drag of your body is 80% more than the bike its not a lot of difference. Since a round tube stalls / burbles all the time, so your still ahead of the game, with an oval / foil / tear drop shape.
Your frame can stall if you ride through someone else’s jetwash - think of being passed by Bjorn. If this happens you can go into a flat spin, and lose control of your bike. Sometimes you can recover from a flat spin, but if you can’t the only option is to eject. Unfortunately, that too can be very risky. Talk to Goose’s widow about it.
If you manage to survive that, you will very likely be seriously depressed. Some quality time with Kelly McGillis is required to come out of that deep a funk. That and a classified story from Tom Skerritt about how your dad “did it right”.
so aerodynamics matters for those of us going under 2h for the bike in an Ironman.
I used to bike on the autobahn in germany, but it’s not challenging anymore! :wink:
(couldn’t help that…we just had a chat with my training partner about stupid training workouts…too much sun on the head)
