Aerodrink vs. horizontally mounted water bottle--a HIGHLY SCIENTIFIC comparison
Okay, so I’m genuinely curious as to which system is better. Of course, this is an ambiguous question, so I’m going to ask more precisely:
"Which aerobar hydration setup (an aerodrink such as the one Profile makes, or a horizontally mounted 20-28oz water bottle) provides an optimal combination of aerodynamics and convenience?
To answer this question, I am going to do a HIGHLY SCIENTIFIC comparison of the two setups:
Aerodynamics while in a cruising position: horizontally mounted bottle. For most people, this fits right in between one’s arms and is likely shielded from the air by said arms. The Profile aerodrink has that nasty straw, as well as the lower extension of the bottle (this may make the bike a bit slower or faster, depending on headtube configuration).
Aerodynamics while drinking: Aerobottle. To drink from an aerobottle, you simply move your head down slightly and hit up your straw. To drink from a horizontally mounted bottle system, you have to pick it up with one of your hands, which may disrupt the airflow of the front end of your machine.
The real question (to which my HIGHLY SCIENTIFIC method does not know the answer) is: how does the aerodynamics of occasionally moving your arm to drink (using a horizontal system) compare to the aerodynamics of that straw always sticking up (of the aerodrink system)?
Anyway, more comparisons:
Aid stations: horizontally mounted bottle. This seems like a no-brainer. You just ditch your old bottle, replace it with a new full one at an aid station, and you’re good to go. With an aerodrink, you have to manually squirt the contents of the new bottle into your aerodrink, which takes time and is not aero.
Compatibility with bike setups: horizontally mounted bottle. This is a minor point of comparison, but some people just can’t run an aerodrink due to their aerobars being too close to their front wheel, or being too far apart. A horizontally mounted bottle can be accomplished using either of these systems.
Ease of installation: Aerobottle. As far as I know, no one makes a “stock” between-the-aerobars horizontal bottle system (yet). You have to make one yourself. If this is not true, please let me know and I’ll call this category a wash.
Splash factor: horizontally mounted bottle. Though some aerodrinks (such as the Jetstream model) have pretty much solved the problem of splashback, the Profile bottle and most others splash around a lot. Even the Jetstream bottle (which I own) splashes occasionally. Of course, a horizontally mounted bottle can’t splash unless there’s some sort of User Error in tightening the cap or the mouthpiece.
Bike computer placement: Aerobottle. The aerodrink takes up less horizontal space than the regular bottle setup. Some find it more difficult to find a place for their bike computer with a horizontal system taking up all of the space between the aerobars.
Price: Aerobottle. The aerodrinks all tend to be in the $15-$20 range. A horizontal system requires a cage, some other cheap parts and a bit more installation time. Though you can get a cage for cheaper than an aerodrink, the time spent installing (plus the fact that some people purchase a nice lightweight cage that may cost more than $15-$20) gives the very slight edge to the aerobottle on this one.
AND THE WINNER IS: horizontally mounted bottle system, barely. The horizontal system edges out the aerodrink in the non-aero categories, and may be slightly more aero than an aerodrink, depending on the interaction between the aerodrink and the headtube, as well as the comparison of the aerodrink straw vs. moving one’s arm to drink out of a horizontal bottle.
Lastly, if anyone has any actual scientific data that compares these two setups, that would be an awesome resource to post here.
However, any more HIGHLY SCIENTIFIC (i.e. N=1 observations) data points on this topic are also welcome :slight_smile:
everything would be great with the horizontal except I cannot find a place to put my garmin. For me, there is also something about a straw hitting me in the face that also tells me I need to drink more.
What’s highly scientific about this?
Everything! Don’t you see the SCIENCE everywhere in my post!!??! :slight_smile:
In that case you are probably better of without that straw in your face. Your body should get thirsty, before you start drinking serious amounts. Get that straw out of your face and drink when your body tells you when to drink!
Until you put some numbers down, it’s only a qualitative comparison. You need to go into details such as:
  • Time spent in various positions
  • Aerodynamics of these various positions
  • How much does “splash factor”, price, installation factor in
For a more scientific treatment of hydration systems, I highly recommend Mark Cote’s undergraduate thesis (mitaerobike), available somewhere on this forum. It doesn’t discuss horizontal mount bottle systems though, but Mark goes into details such as length of the straw on a profile aerodrink (it makes a surprisingly big difference) and the fore-aft position of the aerodrink on the aerobars.
I know that. I was being sarcastic in both my original post and my response to your comment. In fact, I noted in my original post that have no data and am simply making observations.
Perhaps I should have used pink font!
With a an aerodrink bottle it is a LOT easier to mix a concentrated solution of whatever into it. Far as I can tell that would be impossible with a horizontal bottle.
Only this is highly scientific enough to not use an aerodrink in races to where you need to refill. I have seen people riding like drunks in order to get sportsdrink into there aerodrink. They do that every hour once or twice, and still think it is an advantage. They are a danger to themselfs, other athletes and volunteers beside being minutes slower with that aerodrink compared to what they would be without one. The funny thing is that I see very few truly fast cyclists using these aerodrinks in long course races. Every seriously thinking athlete knows how much slower you are with one of these bottles on your bike.
I like the winner of your highly scientific study. Your scientific paper is accepted. But personally I would give the aerodrink way less points. It is in my opinion only a serious option in races where you don’t want to refill them.
Agreed re: the pink font.
There’s a rule about this somewhere, although I can’t remember the name for it. Something about no matter how absurd or sarcastic a post is, someone is still going to take you seriously… (=
One should probably drink *before *their body tells them. That’s why I prefer the Aerodrink system. If used correctly, they actually splash very litte. (This is from MY highly scientific test of riding the potholed streets of Chicago)!
yep, some nazi will always take it seriously
oh and now ive evoked ANOTHER internet rule
yep, you should get that straw off your face, soon as possible.
This only applies if your race hands out water bottles that fit in bottle cages. The local HIM here hands out water in plastic Deer Park bottles. I guess you could fit it in the cage but it wouldn’t be very tight and drinking from the bottle on the fly might be a little harder. I don’t think filling the Aerodrink on the fly is very difficult and is a little more versatile.
what garmin? if a 705 put on stem if 305 use FSA’s computer mount , I used it and now my 305 isout of the way. Can get cheaper version on ebay
How about this question – If an aero bottle was integrated into the front end of a bike, would you prefer it over carrying a horizontal round bottle and/or a frame bottle?
How many people like the 22 oz, 28 oz, or ~50 oz Profile bottles? Who use what for which event? I raced a development Shiv with the Aerolite at Vineman and had generally good results except for the cap and general movement of the bottle.
Any opinions on not what exists today but what the absolute ideal aerobar hydration product could be?
Mark
Few things:
Regarding ease of installation, Vision makes, or rather made, a carbon half-circle cage called the Drinkmore. Was designed for a horizontal bottle mount.
I think I recall Tom Demmerly doing a write-up on it here on the forum. I have one & like it quite a bit. Actually, I really like the normal bottle between the aerobar mount, but I can’t get the bottle to stop popping out of the cage on bumps. Maybe it’s a bad install, maybe it’s the fault of there being nothing to hold the bottle in on the top side. I plan to keep tweaking it, but maybe end up jimmying up a normal cage up there instead.
I tried the aero drink, and while I love the convenience of not having to leave aero, I couldnt stand the splashing & rattling. Yellow stuff, black cap, duck tape, you name it…it kept spilling and rattling. Might be nice on pristine roads, but sucks in Chicago. Plus I can basically stay in aero with a horizontal bottle or a rear-mount anyhow, so I’m not too worried about it.
Are you guys actually just setting a normal sized water bottle on the aero bars? OR are you securing it in some fashion. I would think a bottle just sitting there would eject (or simply roll out) very easily. Especially on a really bumpy road or tight turn.
Am I thinking of this wrong?
read the original post re “Price”. yes, you need a cage and at least a few zip ties.
I think the Speedfil is the best thing out there, Mark. If you guys developed something similar that worked with Specialized bikes then I’m sure that would be a step up.
The aerodrink is in a bad position on the bars and I really don’t like the aerobar addon with the water bottle because it junks up the cockpit. For those of us who mount a 705/SRM computer/bike computer in between the aerobars it’s really irritating to have additional bottles and stuff in there. Additionally, if you turn the handle bars–and even though the seat is where steering comes from, EVERYONE turns their handle bars on purpose or accidentally at some point during a race–there is a lot of sloshing that can happen to aerobar mounted drink holders. So the speedfil position keeps the aerobars from being overly crowded with stuff, makes it easy to refill during a race, and keeps sloshing to a minimum.
Some internally mounted drink system would be great but I cannot see that realistically happening anytime soon.
Mark
