Aerobar hydration options
Hi, I am looking for ideas on what options I have available for hydration systems between my aerobars. I realize there are plenty of options out there and have found some great write ups and types. However my main issue is that I am not able to find a hydration mounting bracket etc that is wide enough to fix on both of the aero bars. I prefer to ride my PRO Missile bars on the wide fixing of the two available for comfort reasons, however none of the hydration mounting brackets seem to go wide enough to fix to each of the bars. Any ideas?
Cheers :slight_smile:
How wide are your extensions? Measured from center of each extension to the other?
Take a look at Alden Designs.
They offer several sizes from:
Narrow: 70mm - 100mm Center
Standard: 90mm - 120mm Center
Wide: 100mm - 140mm Center
Custom: Can go up to 220mm
http://alden-designs.com/uploads/3/0/7/4/3074974/__9248322_orig.jpg
xlab toredpo and speedfil maybe
Hi, the gap where the water bottle system is needed is 180mm and narrows where the hands are held. Many thanks.
