Ok, seeing the photo I remember now. It was a âmeâ problem. I donât have a non-disc rear wheel for the mag sensor. And the magnet wasnât at the correct location to clip to the cutout for the valve stem on the disc.
I tried using the front fork and front wheel but the angle the magnet passed wasnât right versus mounting the sensor on the rear chainstay.
So mostly a âmeâ issue to need a cheap non-disc rear wheel I can clip the magnet to.
I end up using the magnetic sensor when testing a tri-spoke/disc wheel combo.
Best mag sensor I ever used was from SRM, but all the Garmin, Wahoo, mag and non mag sensors work fine for me.
There is a big component of how the aero device handles the speed sensor signal
As far as I understand, outdoor testing should be done with the most basic wheelset anyway to avoid possible yaw effects with high rim profiles and discs.
Of course, this is not possible if comparing wheelsets but that is not what most people change all the time. There is a nice episode on the Endurance Innovation Podcast with the aerotune guy (Sebastian Schluricke) on this topic.
I use the SRM sensor on the fork at the front wheel and I believe itâs the same as the old garmin model. Also, there are different types of the spoke magnet so itâs maybe worth playing with those if there are issues.
I have at least 10 different ANT+ magnetic speed sensors, just not to run into a supply chain problem.
I have some speed sensors from SRM, but I think these are just rebranded sensors from East Asia. Magnetic sensors are all very similar, i.e. they indeed deliver speed with the ANT+ scan rate of ~4 Hz if cycling fast enough. Their errors are related to the precision of the internal quartz clock. Mounting more magnets onto a wheel does not increase the precision of the clock. In addition, it is difficult to mount several magnets on the same wheel with precise angles in-between (i.e. 180.00° or 120.00° for example).
The magnetic sensors however differ in how precise one must align the sensor and the magnet.
Power meters and speed sensors using the ANT+ protocol do generally not report cadence and speed with the same frequency. Speed sensors I use transmit with ~4 Hz, power meters rarely are faster than 1 Hz.
I am in the same boat as you, trying to get my Notio up and running without any app support. I have an Edge 530 in the mail and will get the Notio widget on Garmin IQ so they can talk. I also have an ANT+ speed sensor and Golden Cheetah ready to go on the Mac and of course the Quarq. Hopefully they will all talk to each other out on the bike outdoors.
E
I cleaned up some mywindsock laps I did Friday when I didnât have the sensor working yet. I wanted to see if I could get the settings right on that site to get consistent laps. So all the outbound lap CDA should be closer together and all the inbound close together.
They were.
I did 9 out and backs all in, about 35 miles. I wore the Nopinz Flow with the TT5 first. Then I found some ribbed âsun sleevesâ that are super tight. I didnât wear them under since the suit isnât designed for that. I wore it over the suit arms. The ribs arenât super pronounced, but theyâre similar to what youâd get with a base layer setup.
The ribs were noticeably quicker.
I think next test with the Notio now working I will repeat that to confirm, but move on to using the sun sleeves as my sock/shoe cover. I had an older pair that I didnât mind and tried it on, it was the beeâs knees as an aero sock thing. If I sacrificed a pair to cut a hole for the cleat I think I could make it work for an entire shoe cover style. Then test that out.
Mywindsock lap I had outbound laps being at a slower moving speed at an .017 improvement and inbound laps being at a faster moving speed (false flat) at an .011 improvement.
Youâre saying that the sun sleeves can be worn over the arms OR the lower legs? .017 is a healthy savings. How far up the arms did they go?
E
Yes, seems both. I originally bought them because on the Chinese photo of the product it looked much tighter on the arm than the âtribal tattooâ skin color sun sleeves I used to use in summer. Bonus feature was I guess they saw everything these days had little ribs on them so they randomly feature ribs the entire length.
They are full arm length, if careful you can get them up to your shoulder and extend to wrist.
I wore them under a cheapo Kalas suit I have that is thicker material and they still gave the arm ribbed texture to the surface. I didnât test that suit because the rest of that suit is a dog fit wise. Loose at the chest.
For the shoe/leg thing I was just horsing around at home trying old suits on and thought âhey, those Fastest Sock on Planetâ deals looked similar to the sun sleeve. So I slid them up my calf. Worked. If you shove the excess in your shoe instead would work also, I havenât tried sacrificing a pair yet for a hole for cleats to try as a shoe cover.
But the material theyâre made of is super thin stretchy. I feel like if you get an outdoor riding season out of a pair you did well, then toss em. Theyâre cheap enough and maybe cheaper than bathing arms in sunscreen.
I would say thinner material than something like a skinsuit made for a base layer.
Itâs under a few names on Amazon or Aliexpress, but theyâre essentially ribbed sun sleeves.
Why is a magnetic speed sensor necessary? Iâm mostly using an accelerometer based speed sensor and getting good speed readings. In the end both sensors measure changes, the magnetic one sees a change in a magnetic field once per revolution (+/- 2 meters) and the acceleration based one sees a sinusoidal change of gravity (+ some centripetal acceleration which is relatively constant when the speed is constant). The only issue I see is filtering out road vibrations.
I donât know if this helps but the Notio has an accelerometer but I use it with an ANT+ speed sensor. I played around with the accelerometer in other disciplines but not sure how it helps the sensor tease out CdA.
E
The sensor I mean also connects via ANT+, the accelerometer is the measuring principle of the speed sensor. This Garmin uses an accelerometer (and maybe a gyro) GARMIN (NL) | Speed Sensor 2
Thatâs the one I use. I donât know why others are saying magnetic based speed sensors then.
E
Hence my question
This is the most modern, non magnetic version:
source: Google Image Result
This the âoldâ version:
Edit: After diving a bit deeper, Garmin actually uses the magnetic field of the earth to determine the rotation of the sensor. Wahoo uses an accelerometer that measures + or - gravitational acceleration.
As long as they can tell me my Cervelo P4 is faster than my P5 I guess I donât care how they work ![]()
Thatâs interesting about the earthâs magnetic field though.
E
I think in most scenarios a wheel hub speed sensor is good enough. Especially if speed doesnât vary much and doesnât vary fast.
However, in aero testing speed is a crucial quantity because it enters up to the power of 3 into the equations of motion. Why increasing uncertainty by using a more noisy sensor?
It is indeed difficult to find nowadays a dedicated ANT+ magnet-type speed sensor. Another example of a step back innovation. However, I still could find one scrolling down some amazon pages.
(For the nerds: Honestly, I donât know whether a Garmin wheel hub speed sensor reads an acceleration sensor, a gyroscope sensor or a combination of both or another sensor type. Magnet-type speed sensors use simple reed switches.
Both sensor types when using the ANT+ Device Profile Bike Speed can transmit the so-called main data page 0 to the bike computer with up to ~4.04 Hz (every 8118/32768 seconds). In this data page the important info is the time of the last speed event in 1/1024 seconds (this gives a limit for the precision of timing or speed respectively) and the total number of wheel revolutions. From here the bike computer can calculate speed.
In my data above ANT+ streams from Garmin wheel hub speed sensor and a magnet-type speed sensor are evaluated simultaneously with ~4.04 Hz. Magnet-type sensor speed data shows scatter consistent with the ANT+ timing constraint of 1/1024 seconds. Garmin wheel hub speed sensor data show bigger scatter, I suppose the timing of the speed event is less precise than that from a magnet-type sensor.)
I suppose the speed is good enough. The whole way they calculate and the products work makes it stink for folks without very consistent grade roads. You have any little 3 to 5 foot up/down parts of it, they assume the aero changed instead of power into elevation (or speed change). Then it calculates the little disturbance differently on different laps slightly. So it introduces variability I donât care for.
Around here itâs very hard to make it one direction more than a mile without something like this without an hour+ drive out of town.
Example: despite the âfeet per mileâ being low, the sawtoothing profile is very bad for these sensors
