Aero Helmets (12)
Worth it?
Never used them in a race before…am considering one for an ironman.
Yep.
but…possibility of being too hot? not really an issue unless it is superhot?
ps i shave my head completely. heh
mine has possibly the fewest amount of vents of any, and I don’t have too much trouble.
the visorless types I have seen should be less trouble again.
Listen to this:
http://www.triathletemag.com/Assets/Podcasts/MITPodcast_Dec19_2006.mp3
Hello Fulla and All,
Marching to a different drummer … How does this one do in the wind tunnel?
Certainly the shape would be better in a crash.
http://www.casco-helme.de/en/default01.htm Check out Warp II.
Cheers,
Neal
Problem for the U.S. guys i doubt its approved to use here. And i’m not sure how much the shape would matter crashwise as long as there is adequte frontal protection… assuming you go into your forehead.
Grant
Hello cyclonehockey21 and All,
Just curious about a non ‘in-style’ round shape and how it would test in the windtunnel.
You are correct that lower crash standard CEN approved helmets are only approved for some US races.
http://forum.slowtwitch.com/gforum.cgi?post=965748#965748
Cheers,
Neal
Neal,
It completely depends on the person and the objectives of the air flow. Some one had a helmet that didn’t look that aero because it wasn’t sitting right on his back but in the windtunnel it was actually better because it forced the airflow over his rear mounted waterbottles. So its all guess and check when you get into the tunnel.
Grant
