Aero gains from new bar/brake setup?
  1. different front brake for those final seconds. the tririg isn’t worth that much of a savings, 4 or 5 sec over 40k iirc, but it never hurts to be 4 or 5 seconds closer to the finish line then your competitors.
    3-4 sharp turns, and the “saved” 4-5 sec are gone…
    Because the 3-4 sharp turns don’t exist until the Aero Brake is installed.
https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcQxtjpRzeza6sFi_cEfIbhuhSWt5wV69-nZuArCXLAYNzZbFQjw
Once upon-a-time, I did a 40 km TT in Howard County, Maryland called the Extreme TT. Along w/ the usual sharpish ups-and-downs characteristic of the terrain there, the route included a bumpy, twisting descent that ended w/ some zig-zags across two bridges crossing a stream. I was uncertain whether I wanted to use my Hooker TT bike w/ “aero-or-die” handlebars, so pre-rode the course on it along w/ a friend. When we got to the descent, I told him to go full gas, and I sat up and safely coasted all the way down. By the time we reached the bottom of the descent and started climbing again, he had put all of 8 s on me…with such a small difference and knowing that I could safely go even faster on that section on race day, I opted for the Hooker, and finished a respectable 3rd (beaten only by a couple of young Cat 1/2s).
Several things from my aero eyeball, but remember most people tend to have poor aero eyeballs.
  1. more aero basebar /clip ons or integrated bars. I’d also think about changing to ski tips from tose extensions. Lots to be gained here, my guess isn somewhere between 50-125gm of drag reduction.
Ski tips are faster than S bends?
That isn’t the case, I have direct comparison of sharp corners between road bike and TT bike with aero brakes and the differences through the corners are far less than a full second. Don’t think they were because of braking power either.
A cleaner front end would be an aero gain. As would some additional drop on the bars if she can hold the more aggressive position.
you said agressive. you get a time out.
Herbert, Jordan: please give me time out doling out abilities.
ski tips are neither faster nor slower than s bends.
that said she and most others should switch to them.
Here is a description of the aggressive aero position I am referring to: https://www.youtube.com/watch?v=K8O5-mRu1wk#t=104
Todd certainly explains it better with a slow motion video presentation than I can in a text-based post.
I can’t see the video, but is the person on the bike threatening, lunching, taking risks, etc.?
If Todd is a bike fitter then he gets a time out too. He gets a longer one though because he should know better.
Here is a description of the aggressive aero position I am referring to: https://www.youtube.com/…?v=K8O5-mRu1wk#t=104
Though I think I get your drift that might be better worded: aggressive rider, aggressive racing, or just reckless driving rather than an aggressive aero position which seems to be widely used at this point.
there’s no such thing as aggressive… either a position is aero, just right, or it’s not. People need to stop using that term. It is neither aggressive nor un-aggressive. It just is. The fact that this guy keeps rolling out that trope does not reflect well on his credibilty in my mind.
Fighter pilots are aggressive, poker players are aggressive, racers are aggressive, investors are aggressive, Generals are aggressive.
Bike positions are just so, or not.
eric,
you need to get all over bontregor on this, as their saddle white paper calls out “aggressive” road position(as less than aero btw)
