So Christmas is rolling in soon and I’m thinking that I will help my girlfriend upgrade her bike a bit as her gifts this year. She’s on a Cannondale Slice with the stock Cannondale bar/Vision clip-ons and stock SRAM Rival brakes. Was thinking about going to a bar like the Brezza II Nano and a TriRig Omega brake. She races primarily Olympic distance, has an aero helmet and a HED 60/90 setup as well as a Zipp disc. She is pretty small and rides a 47cm Slice so the narrower setup of the Nano seems ideal and with the addition of a TriRig and the cleaner cable routing it seems to me that there would be a much cleaner front end.
Thoughts on whether you guys think this will be a solid upgrade or if the money is better spent elsewhere? She is usually on the podium for her AG at larger events (7th at USATNC & 1st at Hyvee this year) or overall at smaller, local events so were looking for things outside of training that can help make her that much more competitive as she heads into Worlds and other races in 2015.
Very solid upgrade. You might also consider swapping stems to something like the TriRig Sigma and going with one of the Felt Bayonet basebar/aerobar combos.
I think there are several aerobars that would be better than your current one. Also match that up with th TriRig Omega and Sigma (on sale right now) and you could really clean up that front end. I think that would be amazing.
How much money do you want to spend on the front end I guess. Excluding the stem and brake, do yo have a budget. There are several ways to deal with this request.
EDIT: I will be selling my FELT DEVOX aerobars once I have them freshly repainted black which I believe they are done now.
Whatever bar you choose, when you remount the brake levers, you can tidy up the cable housing a bit too, seems a bit long for both the front and rear brake
I would skip the Nano and go with the Brezza II (which you can get super cheap now) or similar. The Brezza II you can get pretty tight on anyway and it’s one of the bars most people use pad extenders for so that gives you an idea of it’s starting point. The Nano could well just be uncomfortable.That and Tri Rig Omega would be a nice upgrade.
The aero benefit is quite small. The negative side with Tririg brakes is the modulation - difficult to get the exact breaking power wanted. Leads into starting to break earlier and more than needed - slower total speed if racing with many turns.
I have Tririg brakes, but reverted to the Campy caliper in front to improve safety and total speed.
Thanks for the input! The front end is going to come down once we get a new bar picked out and can get her into the fitter. She came from a road bike with clip-ons to the current setup this past season so we didn’t go too aggressive with the fit, getting her comfortable on the new bike was priority #1.
Sadly there aren’t many shops around us where we can handle the bars and on paper the Nano seems like a great idea but the potential issues pointed out above make sense as to why we should look to the standard Brezza. Have the opportunity to pick up a brand new Ventus II LTD for under $400 but that seems like a fitters nightmare. Probably looking to stay ~$500 for a bar setup. The brake isn’t a critical upgrade more just thinking along the lines of “Well, while we’re in there we might as well do this”.
If you look at the vision/hed/ventus cervelo data, going from a round base at and clip ons to an integrated nice aerobar is worth about 100 grams of drag at 30mph. An aero base bar will get you about 2/3 of that.
Someone posted a link to the ventus 2 for 475. That’s a phenomenal deal. The SI vision tech setups are very fast on a lower budget and although its not super adjustable it looks like a good match to her current setup.
Thanks for noticing that link, zero replies to the post so I thought nobody had spotted it !! Thought those badboys would be snapped up like hot buns over here on ST.
Several things from my aero eyeball, but remember most people tend to have poor aero eyeballs.
more aero basebar /clip ons or integrated bars. I’d also think about changing to ski tips from tose extensions. Lots to be gained here, my guess isn somewhere between 50-125gm of drag reduction.
Clean up the cabling, even if you’ve got to customize it a bit. but remember measure 3-4x before drilling/cutting etc. Or you can get stems, cable hangers etc that would help as well.
different front brake for those final seconds. the tririg isn’t worth that much of a savings, 4 or 5 sec over 40k iirc, but it never hurts to be 4 or 5 seconds closer to the finish line then your competitors.
depending upon aero helmet change that out. There are some real dog aero helmets out there.
3-4 sharp turns, and the “saved” 4-5 sec are gone…
