I should do a blog entry on this topic since it comes up monthly.
To fully convince yourself you need to do the math, computing time to cover a fixed distance given a change in CdA.
If you don’t actually do that math, and instead think about power requirements or intuition you just aren’t going to get it enough to be convinced.
Now you can do that by hand but if you don’t have the skills for that you can use various calculators like analyticcycling.com or cyclingpowerlab.com, or bestbikesplit.com
They all use the same underlying, simple physics equations.
So let us take a given scenario, a rider who does 300 watts with a CdA of .25 on a flat course at .004 crr and normal air density will go about:
42.62kph
Reduce CdA by .005 (equivlent to 50g drag@30mph) and speed goes to
42.89kph
An increase of 0.27kph
Now, same experiment for a lower power rider, just 200 watts, his speeds will be
36.63kph and 36.86kph
an increase of only .23 kph (less!)
So you go from 300 watts to 200 watts and assume the same drag? That makes no sense to me, unless you’re selling bikes.
I did math too, ignoring a lot of other resistance obviously.
F = CdA * Air Density x velocity ^2/2
Assume your .25 CdA * 1.23 * 10m/s ^2/2 (an optimistic age grouper speed at an optimistic CdA)
I get 15 newtons which must be multiplied again by the velocity to get 153 watts.
Do the same math at wind tunnel speeds (13.4 m/s) and you get over 368 watts.
My age grouper has slown down to 75% the original velocity and needs 41% of the original power.
If a helmet measures 5 watts saved at wind tunnel speed, there is no way that is linear. 5 watt savings in 368 is great but 5 watts out of 153 (or even 75% of 5) is inflating that number significantly. I would guess using this that instead of 5 watts advertised you get 2 while reducing velocity by only 25% from advertised. That isn’t linear.
If I’m wrong, please show me where. But I would ask that we keep the links to cervelo.com to a minimum, really the company that sells bikes is trying to prove that slow people should buy superbikes too? Gasp!
And you’ve just proven once again why aero test results should be reported in terms of CdA…not watts…not “grams of drag”…etc. All that does is cause confusion. CdA allows for the user to calculate WHATEVER metrics they desire without additional information about the test.
Anyway, your confusion in this case is because you haven’t done ALL the math…keep going, you’re almost there…but first you may have to set aside your preconceived notions for a bit
The reason that I posted links to Cervelo is because they HAVE done all the math
It’s all basic physics and math…not rocket surgery.
