After reading tons of comments about these, I decided to get them. My only concern is about installation, how do they sit on the drive side of the wheel? Is there a minimum clearance between the big cog and the spokes for them to fit properly? I don’t want to order them and later find out they don’t fit or something.
The cover will rest against the hub away from the cogs.
I found that I had to tape the cover to the spokes on the drive side so the read der. wouldn’t hit it. After I had it on a few times I got better at it.
I had an issue when I got one for use with an older white industries hub on a lew wheel. I contacted Rich from wheelbuilder.com
his reply: 5mm is the distance required to clear your derailuer and cog set. If the chain and deraiuler are not touching the cover it is possible to just open up the center hole. Barb
Had an interference issue with the White Industries hub. Solved it by rolling a flat sheet of coarse sandpaper into a cone and opening up the hole. Didn’t take much. Two seasons later I bought a Renn 575 and the wheel covers are hanging on the wall
I’m also interested to buy the disc cover, because I don’t want to spend $600+ on a Disk that I’ll use 4-6 times a year.
I have one question for you guys and your help will be very appreciated. My wheels are Mavic Cosmic Carbone; I have to tell Wheelbuilder the measurement of my wheel so he can cut it, but I don’t know if it’s the full rim depth or where the spokes ends.
See this picture… A is where the spoke ends on the rim and B will be the full rim… Do you have any idea which two is the correct meassurement?
