Aero bar mounting question
I’ve recently bought T2+ cobra aero bars, along with cobra base bar (Profile Design) from a fellow STer. I bought the arm rests and pads at my LBS but realised I don’t have the required mounting equipement: can someone please tell me what I need to buy to mount aero bars ands arm rests on base bar, as well as where to find it? Thanks a lot
Nic
Since the aero and base bars are from profile design and, hopefully, so are the elbow pads, you can ask your lbs to contact profile designs directly at 310-884-7756 to get your necessary parts. Or, you can contact them yourself.
problem is, the kid at lbs this afternoon didn’t know much about tri bikes and bars. He couldn’t find the part #. Thanks for the number, I will call them tomorrow.
There is a bracket that clamps onto the base bars and holds your aero bars. The elbow pads then slide onto the aero bars. The bracket is probably available at you LBS, or contact Profile Design, or web search.
Here’s a pic of the bracket (inside the pink circle):
http://i39.tinypic.com/2r4oikg.jpg
(This is the alloy T2+, and not the Cobra, but you can at least see the bracket).
Exactly what I am looking for, thanks a lot.
