I have long arms which, combined with my short torso and long legs, make me look comical. That’s something I guess I will have to live with. What I won’t live with is the fact that my hands get past the point of the front end of my current aero bar extensions. I want to buy new ones but
a) I don’t know much about the subject, and
b) I apparently don’t have the necessary internet skills required to find out if there are any compatibility issues with the cockpit of my plasma and bar extensions from different brands.
From elbow to the tip of my middle finger there is 50cm (and 30cm to the wrist). I`d love upturning extensions but flat ones aren’t a deal breaker. The main thing is length and that I don’t need to change my SRAM gear cables or the Plasma cockpit.
Those look like profile design T5 extensions. I was able to find that they are 380mm in length, same as the Zipps. Tri Rig has 400mm of length so you could gain another 2cm with those extensions. I would want to have a little bit more of the extension extending back at the clamp. You have none.
Precisely. Measured mine and they are 30cm. Should be enough with 38, but thanks for the link to profile design too. Do you have Alu or carbon? Any difference besides weight?
The zipp carbon have better internal routing for the cable. Like a built in little slot so you don’t have to use bar tape to cover it. I’m selling a new pair of Zipp Vuka evo 70 carbon Uncut, so full length If you are interested.
I’m also riding a Plasma and found the stock extensions way too small. I tried several different options, including Zipp Vuka Evo 70 and 110 (ended up selling both). I’ve been on some carbon RedShift ski bends that I like, but just ordered some Profile Design 50a, which are 400 mm (my RedShifts are 380). The 50a extensions haven’t gotten here yet but once I decide which I like better the other pair will be up on the classifieds if you’re interested (shipping from the US though).
The plasma is pretty compatible with a number if bars. The tririg bars are incredibly long, I used to have them. I currently use the zipp bars and they are pretty long as well.
