I’ve been on the search for adjustable length cranks since developing IT band/hip flexor/back issues from last year’s riding. I am getting professionally fit on a 2009 P3 this year at my local LBS, but they haven’t worked much with different lengths of cranks. I’ve compiled a short list of adjustable cranks that I have found instead of dropping upwards of $500 on carbon cranks for experimentation. I would really appreciate if anyone else has had any luck to chime in! Ideally I would like adjustable carbon cranks mainly for cosmetic reasons, but would definitely consider steel or aluminum if there was a weight benefit (again only ideally since this will be my dream bike ;). FSA only makes a compatible 165mm carbon crankset in a triple which will work but is $520.
Joe
Adjustable carbon cranks - inexpensive for carbon, but not sure of quality
http://home.intekom.com/murraytourdeforce/cranks.htm
PowerCranks - heavy and expensive, but potential for performance benefit
http://www.powercranks.com/products/powercranks.htm
Stronglight - not an option, want to move down to 160mm, but an ingenious design
http://www.stronglight.com/stronglight/page.php?nom=produit&keyProd=fission
Racermate - not an option either, want to move down to 160mm
http://www.racermateinc.com/varicrank.asp
High Seirra - not carbon, unsure of fit or weight at this point
http://www.hscycle.com/Pages/adjustablecrankset.html
